Vector Field Plots
Is there any good built-in way to do a vector field plot in Igor?
Igor
It really depends on the dimensionality in question. In IP6 there is a demo experiment for a 3D vector field. Go to File Menu->Example Experiments->Visualization->Advanced->Scatter Arrows. A 2D example is in File Menu->Example Experiments->Graphing Techniques->Arrow Plot.
HTH,
bech
Let me add my support to the (implicit) request here. I have looked at the "Arrow Plot" demo, and it is far too complicated to be useful in practice. What is needed is a plot type analogous to "Contour Plot"s, which would just need a matrix and then be able to make a quick plot, with a dialog to adjust appearance.
John Bechhoefer
JimProuty
bech wrote: Let me add my support to the (implicit) request here. I have looked at the "Arrow Plot" demo, and it is far too complicated to be useful in practice. What is needed is a plot type analogous to "Contour Plot"s, which would just need a matrix and then be able to make a quick plot, with a dialog to adjust appearance.
John Bechhoefer
What's the usual data format for the 2D vector plot?
A 2D complex matrix?
For "adjust appearance" is there much beyond a scale factor for the vector lengths?
bech
John Bechhoefer
In the Igor context, it would either be a function, a REAL matrix, or possibly a set of XY pairs. Igor would then have to do some work to numerically estimate the local gradient and then come up with the arrow. This would be a task analogous to the work required to figure out contours in a contour plot. (Indeed, the arrows are, of course, just locally perpendicular to contours, so the same routines might be used in both.) On the same topic, a streamline option would also be useful. (This is a plot of lines that are generated by "connecting the arrows all together to form a curve" and are, again, perpendicular to contour plots. They correspond to integrating the 2d-ODE associated with the vector field.)
Not usually, but perhaps an option.
Well, there would be color and other graphics parameters (thickness, arrow-head shape, etc.) for the arrows themselves (+ option to have either just lines (no arrow heads) or "nails" (flat heads) are also useful. For streamlines, all the options in contour plots would be useful.
John Bechhoefer
bech
We finally had a need to do a vector-field plot. The built-in option that now exists is great! (Confession -- at first, it didn't work; then I actually read the help file carefully and realized that the length units are points, not the graph xy units, and also that 2d wave format is r-theta and not xy. After that, it was smooth sailing.)
Belated thanks to the Igor folks for adding this!
