How to call 'Scaled Dimension Index' of particular data point if I know it's row index and column index?
I want to re-scale the "Scaled Dimensional index" of a two dimensional wave. For this I need to know the 'Scaled Dimension Index' of particular data point from it's row index and column index.
s.r.chinn
Here is some example code to get you started for your particular needs:
function foo()  // make a test wave
	Make/O/N=(13, 9) wave0
	setscale/I x, -0.6,  0.6,"" wave0
	setscale/I y, -4.0,  4.0,"" wave0
	wave0 = Gauss(x, 0, 0.2, y, 0, 2)
function bar(rowIndex, columnIndex) // test the function below
	variable rowIndex, columnIndex
	WAVE wave0
	Wave wOut = ScaledDimIndex(wave0,rowIndex, columnIndex)
	print wOut
function/WAVE ScaledDimIndex( InputWave, rowIndex, columnIndex)
// returns the x and y scaled dimension indices as a two-element wave
	wave InputWave
	make/O/N=2 wOut
	variable xx = DimOffset(InputWave,0)+DimDelta(InputWave,0)*rowIndex
	variable yy = DimOffset(InputWave,1)+DimDelta(inputWave,1)*columnIndex
	wOut = { xx, yy }
	return wOut
When testing this, you should see:
•bar(1, 1)
  wOut[0]= {-0.5,-3}
as the {x, y} values for point indices [1][1].
Note the core functions DimOffset and DimDelta for use with multidimensional waves.
ikonen
Use:
scaledposition = DimOffset(waveName, dim) + index*DimDelta(waveName,dim)
for each dimension that you need the scaled position (0 and 1 for rows and columns respectively)
I would normally suggest using SetScale to "re-scale" the dimensions of a wave, but you don't need to know its current settings to do that, so I'm not sure that's quite what you're asking for.
Pranab
@s.r.chinn and @ikonen - Thank you very much! You have given the exact answer, I was looking for. Part of my problem is now solved. For quick checks, I am using DimOffset and DimDelta. But I am writing a macro to process several waves, where chinn's elaboration is very helpful. Thanks!!!
Pranab
I need to know the scaled dimension value first to determine the re-scale value. I am writing a macro, and I need to call it.
