Category plots: a serious limitation in Igor Pro?
I am facing serious limitation in Igor pro. I have data points on the y-axis going from -15 to 5. The category plot can only be plotted growing up from zero and hence my column is inversed. I tried every single way to try to plot a column growing upwards from -15 to 5 but failed.
Any suggestion?
Kind regards,
Katy
Here is an example. Note that the idea that the column grows from (e.g. -15 to ~-7). You could argue that we could reverse the y-axis but that will leads to illogical order of the y-axis. So I wished to have the circled black symbol sitting at the top of the column not at its bottom?
I think the problem is to do with that the base line of category plots is always set to positive number or zero but negative values are not possible! A real challenge!
Thanks
Katy
Would this do what you want?
categories		data		minus15
	a		-6.5		-15
	b		-8		-15
	c		-9		-15
	d		-11		-15
	e		-7.5		-15
	f		-7		-15
Window categoryFromMinus15() : Graph
	Display /W=(39,273.5,433.5,487.25) data,minus15 vs categories
	ModifyGraph mode(minus15)=2
	ModifyGraph toMode(data)=1,toMode(minus15)=2
	SetAxis left -15,0
EndMacro
Here's another way to do it. Like Jim's this requires some trickery:
Make/O/T categories2 = {"a","b","c","d","e","f"}
Make/O data2 ={-6.5+15, -8+15, -9+15, -11+15, -7.5+15, -7+15}	// Original data plus 15
Display data2 vs categories2
ModifyGraph offset={0,-15}
SetAxis left, -15, 0
