Font size of TitleBox
Hi there!
I just encountered an issue regarding the font size of the TitleBox. By default it is set to 12 (fSize=12), but one can obviously choose also smaller font sizes. The point is that when I set the font size smaller than 12 the actual font size in the TitleBox does not change. I am not sure if this is a limitation of the OS (Windows XP) or did I miss something here?
Cheers,
Gregor
JimProuty
If the font is a screen font, it may not actually be available in the size you chose. The operating system will supply the closest available font size. This is not an Igor-specific behavior.
Try explicitly choosing a font that is TrueType or OpenType. Use the Fonts control panel to view fonts and their properties (look for "TrueType font file" in the Details section of the font's Properties panel (when you right-click the font and choose "Properties").
