Moving several data folders
Hello everyone,
I am trying to move (or regroup) several data folder into pre-defined data folder. My goal is regrouping them to use another function to concetenate them into single waves. Here is an example which shows the data folder structure in my case:
-> root
+ DataFolder1_0000
+ DataFolder1_0001
+ DataFolder1_0002
+ DataFolder1_0003
+ DataFolder2_0000
+ DataFolder2_0001
I would like to create two new data folders (DataFoldersGroup1 & DataFoldersGroup2) and move the data folders ending with "_0000" into DataFoldersGroup1 and all other data folders into DataFoldersGroup2. Does anybody have an idea?
Emre
Here is a starting point:
Function Demo(sourceDFPath, destDFPath, suffix)
	String sourceDFPath	// e.g., "root:" - contains data folders to be moved
	String destDFPath		// e.g., "root:Group0"
	String suffix				// e.g., "_0000" to move data folders with that suffix
	destDFPath = RemoveEnding(destDFPath, ":")	// Remove trailing colon if any
	NewDataFolder /O $destDFPath
	DFREF destDF = $destDFPath
	String topDF = sourceDFPath
	Variable numDataFolders = CountObjects(topDF, 4)
	Variable index
	for(index=numDataFolders-1; index>=0; index-=1)		// Do in reverse order
		String dfName = GetIndexedObjName(topDF, 4, index)
		if (strlen(dfName) == 0)
			break
		String regExp = ".+" + suffix + "$"		// Match suffix at end of string
		if (GrepString(dfName,regExp))
			String dfPath = topDF + PossiblyQuoteName(dfName)
			String destPath = destDFPath + ":" + PossiblyQuoteName(dfName)
			if (DataFolderExists(destPath))
				Printf "Can't move \"%s\" because it already exists in dest\r", dfPath
				MoveDataFolder $dfPath, destDF
Thank you so much. It is now clear to me. I will test it and post the results.
Cheers,
Emre
I was wondering why do we need to do all in reverse order? When I move data folders they are in reverse order and this causes some problems for the next step. I tried to change it. However it doesn't work entirely. What am I doing wrong? First function works correctly but the second function moves only the first data folder and skips the second one (when I have two data folders ending with _0000 and two ending with 0001 and 0002).
Best,
Emre
Function TidyUpFTData(sourceDFPath, destDFPath, suffix)
	Variable index
	for(index= 0; index <= numDataFolders-1; index += 1)		// Other way around???
			break
Function TidyUpRealData(sourceDFPath, destDFPath, prefix)
	String prefix				// e.g., "WIBS" to move data folders with that prefix
	Variable index
	for(index= 0; index <= numDataFolders-2; index += 1)		// Other way around???
			break
		String regExp = prefix [0,3]						// Match prefix at beginning of string
Because otherwise index and numDataFolders will be wrong.
You can probably fix this by decrementing index and numDataFolders after calling MoveDataFolder.
Could you please explain what you mean? I tried it other way around and works for upper part of the code. However, it fails somehow for the lower part. It doesn't make any sence.
Assuming you are moving data folders in forward order, when you move a data folder out of the parent data folder, numDataFolders is 1 fewer than when you started so you must adjust its value by subtracting 1 from it.
Similarly index is affected by the fact that you moved the data folder out of the parent and you must adjust its value by subtracting 1 from it.
Thanks for the comment. I learned something new about the "index". The problem with my code was that index changes if I move a data folder and this needs to be corrected by adjusting index to zero to be able to start looking frim the top of the list. Now it works pretty good.
	Variable index
	for(index = 0; index <= numDataFolders-2;)		// Do in reverse order
			break
			index = 0
			index += 1
	Variable index
	for(index=0; index <= numDataFolders-3;)		// Do in reverse order
			break
			index = 0
			break
