Panel with 'Enter' as default Ok button action.
I'm trying to build a small panel, that is supposed to resemble a dialog. Purpose is to enter a numeric value and store it in a global variable. The panel has for this purpose a SetVariable field and two buttons (OK and Cancel).
I'm handling the button actions via proc calls. Entering a value in the field and using the mouse to cancel or confirm the set value works fine.
What I miss is having the Return/Enter Buttons on the keyboard act as if clicking the corresponding button. I can't help but find no way to handle this?
With best regards, Lars Sölter
Function /S UI_NVarInput( varname, panelname ) : Panel
	String varname
	String panelname
	String windowname
	String usrdat = ""
	String tmpvarname = varname+"_DNVI"
	NVAR numvar = $(varname)
	NVAR tmpnumvar = $(tmpvarname)
	usrdat = ReplaceStringByKey( "NVARNAME", usrdat, varname, "=" )
	if( NVAR_Exists( tmpnumvar ) == 0 )
		Variable/G/D $(tmpvarname) = 0
	if( NVAR_Exists( numvar ) == 1 )
		tmpnumvar = numvar
	usrdat = ReplaceStringByKey( "TMPNVARNAME", usrdat, tmpvarname, "=" )
	NewPanel /FLT=2 /K=1 /N=UI_NVarInput /W=(267,122,586,236) as panelname
	windowname = S_name
	SetDrawLayer UserBack
	SetDrawEnv fname= "Segoe UI"
	DrawText 15, 30, "Name"
	SetDrawEnv fname= "Andale Mono"
	DrawText 60, 30, varname
	DrawText 15, 55, "Value"
	SetVariable PanVar1 value=tmpnumvar, title=" ", pos={60,40}, size={240,10}, limits={-inf,inf,0}, font="Andale Mono"
	Button ButtonOk, pos={140,78}, size={70,22}, userdata=usrdat, proc=UI_NVarInput_Ok, title="Ok"
	Button ButtonOk,font="Segoe UI"
	Button ButtonCancel, pos={230,78}, size={70,22}, font="Segoe UI", userdata=usrdat, proc=UI_NVarInput_Cancel, title="Cancel"
	Button ButtonCancel,font="Segoe UI"
	return windowname
Function UI_NVarInput_Ok( s ) : ButtonControl
	STRUCT WMButtonAction &s
	String varname
	varname = StringByKey( "NVARNAME", GetUserData( s.win, s.ctrlName, "" ), "=" )
	String tmpvarname
	tmpvarname = StringByKey( "TMPNVARNAME", GetUserData( s.win, s.ctrlName, "" ), "=" )
	switch( s.eventCode )
		case 2: // mouse up
			if( NVAR_Exists( tmpnumvar ) == 1 )
				if( NVAR_Exists( numvar ) == 0 )
					Variable/G/D $(varname) = 0
				numvar = tmpnumvar
				KillVariables /Z $tmpvarname
			KillWindow $s.win
			break
	endswitch
Function UI_NVarInput_Cancel( s ) : ButtonControl
	String tmpvarname
		case 2: // mouse up
			KillWindow $s.win
			break
	endswitch
You need to use a Window Hook function. Here is an example of the basic technique:
Function DoneButtonProc(ba) : ButtonControl
	STRUCT WMButtonAction &ba
	switch( ba.eventCode )
		case 2: // mouse up
			// First, do whatever needs to be done, then close the panel
			KillWindow Panel0
			break
			break
	endswitch
Function DefaultButtonHook(s)
	STRUCT WMWinHookStruct &s
	Variable hookResult = 0
	switch(s.eventCode)
		case 11:				// Keyboard
			if (s.keycode == 11 || s.keycode == 13)		// linefeed or carriage return
				KillWindow panel0
				hookResult = 1
			break
	endswitch
	return hookResult		// 0 if nothing done, else 1
Window panel0() : Panel
	NewPanel /W=(150,50,450,250)
	Button donebutton,pos={113,87},size={50,20},proc=DoneButtonProc,title="done"
	Button donebutton,fColor=(0,0,65535)
	SetWindow kwTopWin,hook(defaultbuttonhook)=DefaultButtonHook
EndMacro
First, run Panel0(). Then try clicking the button or pressing Enter.
Read about window hooks:
DisplayHelpTopic "Window Hook Functions"
My example uses a named hook function, which is preferred:
DisplayHelpTopic "Named Window Hook Functions"
Since you're using window hook functions anyway, why not extend them to enable increment/decrement of the setvariable control (I know it's not what your asking for but why not?).
Function SetVariableHook(s)
	switch(s.eventCode)
			if (s.keycode == 30)		// linefeed or carriage return
				//increment the setvariable in your panel
				hookResult = 1
			elseif (s.keycode ==31)
				//decrement the setvariable in your panel
				hookResult = 1
			break
	endswitch
	SetWindow kwTopWin,hook(defaultbuttonhook)=DefaultButtonHook, hook(setvariablehook) = SetVariableHook
EndMacro
I added the setvariable hook to John's Panel
