FFT Programming (Magnitude and Phase), Please Help
Hi everyone,
I've been using Igor Pro for about five years now, however I have only just ventured into the art of programming. Currently I am attempting to modify a prexisting experiment that performs FFT on interferometric fringe patterns. The original function listed below works well but only outputs the Magnitude of the Fourier Transform:
Function RealTimeFFT2(w,windowing,resolution,limits)    //designed to do a fast FFT of wave named "w"
//w is considered to be an optical spectrum from the ocean optics CCD.  The routine takes the wavelength x-axis from
//"Wavelength" and converts it to the proper frequency scaling before FFT.
    string w
    variable windowing  //This is the windowing: 1= None; 2=Hanning
    variable resolution //Resolution enhancement: 1, 2, 3, 4, 5, 6 are: none;2;4;8;16;32 respectively.  Actually just determines how many data points are in the FFT
    variable limits
//Modified from Wavemetrics Library
//Given an input wave ( doesn't have to be a power of two), creates a new wave
//with the suffix "_Mag" that contains the normalized frequency response
//Several levels of resolution enhancement (really just sin x/x interpolation) are provided.
//Options include windowing (Hann) vs no windowing.
    string destw=w+"_Mag"
    Variable n      //= numpnts($w)
    variable start_point, end_point
    if (limits) //want to do FFT only on portion of spectrum selected between the cursors in the spectrum window
        NVAR GCursorAPoint_spectrum=GCursorAPoint_spectrum
        NVAR GCursorBPoint_spectrum=GCursorBPoint_spectrum
        GCursorAPoint_spectrum=pcsr(A,"Graph4")
        GCursorBPoint_spectrum=pcsr(B,"Graph4")
        start_point=GCursorAPoint_spectrum
        end_point=GCursorBPoint_spectrum
    else    //do FFT on entire spectrum
        start_point=0
        end_point=numpnts($w)-1
    if( (resolution<1) %| (resolution>6) )
        Abort "resolution out of range"
    resolution=2^resolution     //convert this resolution value to the appropriate binary number (if file length is 2^n, it speeds up the FFT algorithm)
    //resolution -= 1
    Duplicate/O/R=[start_point,end_point] Wavelength, xData
    xData=1/xData       //X axis will be 1/nm so FT will be in nm
    Duplicate/O/R=[start_point,end_point] $w, yData
    Sort xData, xData, yData    // sort by increasing X
    Duplicate/O yData, tempFFT  // make tempFFT file to contain properly scaled waveform
    SetScale/I x xData[0], xData[(numpnts(xData)-1)], tempFFT   // set the range of X values
    tempFFT = interp(x, xData, yData)
    if(windowing==2)
        Hanning tempFFT; tempFFT *= 2           //assumes continuous rather than pulsed data
    n= numpnts(yData)
    Redimension/N=(CeilPwr2(n)*2^resolution) tempFFT        //pad with zeros to power of 2
    //print "resolution is " +num2str(resolution)
    //print "Ceilpwr2(n) is " +num2str(CeilPwr2(n))
    //print "number of new data points is " +num2str(CeilPwr2(n)*2^resolution)
    FFT tempFFT
    Wave/C tempFFTC= tempFFT        //this resets the complex part of FTspectrum, which was generated in the fft
    tempFFTC=r2polar(tempFFT)
    Redimension/R tempFFTC
    //NOTE: depending on your application you may want to un-comment the next line
//  $destw[0] /= 2                              //dc is special
    tempFFT /= n/2
    SetScale y,0,0,"Cts",tempFFT
    Duplicate/O tempFFT $destw
I would like to also calculate the phase angle from the FFT. I am basing my modification on the example experiement "MagPhase Demo". As I have previously mentioned this is my first attempt at igor pro programming and while I am slowly learning how it all works, I keep getting an error code near the end of the function, "Function not available for this numbertype", relating to the line ----- tempFFT_Phase = imag(r2polar(tempFFT2)). I believe that this indicates that the wave has not been identified as complex, however I thought I had addressed this previously with ----- Wave/C tempFFT_Phase= tempFFT2.
Any help would be greatly appreciated and as I am still a beginner, example code would be fantastic.
Function RealTimeFFTMagPhase(w,windowing,resolution,limits) //designed to do a fast FFT of wave named "w"
    string w
    variable limits
    string destw_Mag, destw_Phase
    destw_Mag=w+"_Mag"      //Destination file for Magnitude
    destw_Phase=w+"_Phase"  //Destingation file for Phase
        start_point=0
    //resolution -= 1
    if(windowing==2)
    n= numpnts(yData)
    FFT tempFFT
    Duplicate/O/C tempFFT, tempFFT2     //Duplicated Fourier Transformed wave for Mag and Phase analysis
    Wave/C tempFFT_Mag= tempFFT     //this resets the complex part of FTspectrum, which was generated in the fft
    tempFFT_Mag=r2polar(tempFFT)
    Redimension/R tempFFT_Mag
//  $destw_Mag[0] /= 2                              //dc is special
    tempFFT /= n/2
    Duplicate/O tempFFT $destw_Mag
    tempFFT_Phase = imag(r2polar(tempFFT2))  //**************ERROR**********  "Function not available for this numbertype"
    tempFFT_Phase *= 180/PI                     // Convert phase to degrees
    Redimension/R tempFFT_Phase
    tempFFT2 /= n/2
    SetScale y,0,0,"Cts",tempFFT2
    Redimension/R tempFFT2
    Duplicate/O tempFFT2 $destw_Phase
Thanks
imag() returns a real number, not a complex one. So Igor throws an error because you declared tempFFT_Phase to be complex.
Thanks 741, changing
to
Wave tempFFT_Phase= tempFFT2
cleared up the error associated with the imag() tag, however now I receive an error on the very next line:
tempFFT_Phase *= 180/PI wave assignment error: "Complex wave used in real expression."
I thought that the imag() tag converted the imaginary component of the complex wave into a real number, as shown in the example experiment MagPhase Demo.
Thanks again for your fast reply
[quote=baitzer]
[/quote]
There is no conversion here. imag() is a function that returns a real value. If you assign it to a complex wave the compiler will find it objectionable.
The solution to many of these problems is to use MatrixOP. MatrixOP does not care if your input is real or complex. It attempts to give you the correct output as implied by the return values of all the tokens that appear on the right hand side of the MatrixOP expression.
Also note that you were apparently working from a very old example. FFT has a /DEST flag and /OUT flag that would make your code a bit more compact.
Thanks A.G.
Modified my function to include MatrixOP and now it works great.
Hi all,
Thanks again for your earlier help. I just have a few additional questions relating to the phase angle. I modified my original code according to A.G. and 741's suggestions which solved the associated error's I was receiving.
New Code:
    string w
    variable limits
    destw_Mag=w+"_Mag"
        start_point=0
    //resolution -= 1
    if(windowing==2)
    n= numpnts(yData)
    FFT tempFFT
    tempFFT_Mag=(r2polar(tempFFT))
    tempFFT /= n/2
    Variable degree=(180/pi)
    MatrixOP/O tempFFT_Phase=degree*imag(tempFFT2)  // Extracts the imaginary component of the complex wave (Phase) and then Convert phase to degrees via (180/PI)
    Print "test", atan(tempFFT2)
    tempFFT2 /= n/2
    SetScale y,0,0,"Deg",tempFFT2
    Print "Phase", tempFFT2
I have now managed to plot both the Magnitude and Phase on a single graph as shown in the attached image (Magnitude = red, phase = blue), however the phase is massive >20 kDegrees. I thought that the phase extracted from the FFT was between -Pi and Pi or -180 to 180 degrees if converted.
http://www.igorexchange.com/files/images/FFT%20Magnitude%20&%20Phase%20(Zoom).JPG
Does anyone have a suggestion as to why my code is creating such a large phase?
Also the project I am modifying the code for requires the phase angle at the magnitude. Now that I have extracted the phase information from the FFT, how would I determine the phase angle. I can easily find the magnitude via peak fitting the red trace but I am unsure how to determine the related phase angle.
Cheers
You can convert between rectangular (real, imag) and polar (mag, phase) representations of complex numbers using the functions r2polar() and p2rect(). With phase variables sometimes the Unwrap operation comes in handy.
