Insert a graphic inside a graphic
Hi there,
I would like to insert a graphic (as pdf picture) inside a graphic, so I can show a zoomed part of it. I've watched again all the tutorials and made a search here but couldn't find anything like this. I was able to add the picture using the annotation tool, but I cannot resize it.
Is it possible?
Perhaps it's much more easy to use any image editor, but I like the quality of pdf graphics from IGOR :)
Attached is a picture of what I'm trying to do.
Many thanks
Maybe there are better ways, but I have done something like this by adding additional axis to a graph, e.g.
Make test = x
then
Window GraphinGraph() : Graph
	Display /W=(909,210,1551,792) test
	AppendToGraph/L=newaxis/B=newaxisB test
	ModifyGraph margin(left)=85,margin(bottom)=85
	ModifyGraph mode=3
	ModifyGraph marker=19
	ModifyGraph useMrkStrokeRGB=1
	ModifyGraph tick=2
	ModifyGraph mirror(left)=1,mirror(bottom)=1
	ModifyGraph minor=1
	ModifyGraph lblMargin(bottom)=17
	ModifyGraph lblPos(left)=78,lblPos(bottom)=62
	ModifyGraph lblLatPos(bottom)=1
	ModifyGraph btLen=4
	ModifyGraph stLen=2
	ModifyGraph freePos(newaxis)=-310
	ModifyGraph freePos(newaxisB)=-50
	ModifyGraph axisEnab(newaxis)={0.105,0.4}
	ModifyGraph axisEnab(newaxisB)={0.6,0.9}
	Label left "\\Z22 y-axis"
	Label bottom "\\Z22 x-axis"
	SetAxis newaxis 20,30
	SetAxis newaxisB 20,30
EndMacro
EDIT: just on re-reading your post - you want to insert a picture into a graph. Then the above is maybe not what you want, but you could use it to blow up regions of interest.
Thank you!
I have both graphic and picture once I thought it would be easier to add a picture instead of graphic!
But in anyway thanks for the suggestion.
A variant of ChrLie's method is to use a subwindow to embed the graph from which the picture was created into the larger host graph; you may find the mechanics of doing so more convenient.
I recently encountered a similar situation of inserting another graph's picture into a graph. My rationale there was that (a) the picture was created from a graph in another complicated pxp, and (b) the graph was of a large 2D wave. However, I finally concluded that it was much more convenient to import the 2D wave and show it in a subwindow. This allows you to tweak the appearance very easily, rather than go back and forth regenerating a new picture for each minor change.
I'm not entirely sure what you want based on reading the posts above, but it might work to create something like this as an Igor Layout. Go to Windows -> New Layout in the Igor menu bar. You can re-size multiple graphs in a Layout, place them next to or on top of each other, etc. When you are satisfied, you can go to File -> Save Graphics, and export the image in a variety of formats, including as a pdf.
Thanks csmallw!! That's what I was trying to do! It didn't occur me to use the layout! :)
I'll try and I am almost sure it will be as I wanted!
