Fitting curves erratic behavior?
Namely, as the attached image (weirdfit.png) shows, the fitted curve became a straight line for x<5. Despite the apparently incorrect graphics, the parameters I got from the non-linear fit are correct--I used Prism Graphpad to analyze the same data set and the resulting parameters are the same. Also, when I key in the parameters' fitted value in Igor's dialog window and hit 'graph it', I actually got a beautifully fitted curve, with no weird straight lines (shown in correctfit.png)!
Thank you in advance for all suggestions and input!
As you noticed, none of this affects the reported best fit coefficients...the fit routine does use your exact actual X points to find the best fit, but it defaults to a set of points designed to produce a smooth, continuous curve for the destination wave under most conditions.
June 16, 2013 at 05:06 am - Permalink
June 17, 2013 at 10:54 am - Permalink
