Novice programming syntax help please (unknown/inappropriate Name or symbol)
Hi again,
Can anyone help me with something that must be pretty simple but it's giving me a headache. I'm guess it's just a syntax error.
In my code I've got a wave with temperatures and another couple of huge "reference" waves, one with temperature and one with a value that corresponds to each temperature.
The value is the "error" associated with that temperature reading.
I just want to compare each temperature in the small wave with all the temperatures in the huge wave then get the corresponding error value for that temperature, then add it to a smaller wave.
So far I've got this little nested loop thing.
Wavestats TCerror          //V_npnts = num pts in TCerror wave
npts_TCerror = V_npnts
Wavestats AbsTemp          //V_npnts = num pts in AbsTemp wave
npts_AbsTemp = V_npnts
for (i = 0; i < npts_TCerror; i+=1)
	for (j = 0; j < npts_AbsTemp; j+=1)
		if (Temp[i] == AbsTemp[j])
			deltatwt[i] = SigmaDT[j]
Well, the compiler absolutely does not like anything I put here:
if (Temp[i] == //XXXX//)
What am I doing wrong? I've done these if statements before.
hrodstein
You need to tell Igor that Temp is a wave and where it is. For details execute:
proland
For what you are trying to accomplish, use the Interp() function instead of an if statement. This will also eliminate one of your for loops.
phonon
hrodstein wrote: You need to tell Igor that Temp is a wave and where it is. For details execute:
I do. That's just a snippet.
No matter WHAT I put there, I get an error.
I'll keep trying.
edit:
Ok, it was fine with Temp for some reason, but not fine with the other thing there. Earlier I Make those waves and then directly after use them in this if statement. I guess I need to make them or load them, then make wave variables for them to use them?
phonon
proland wrote: For what you are trying to accomplish, use the Interp() function instead of an if statement. This will also eliminate one of your for loops.
Can the interp() function do cubic spline instead of linear with a flag?
hrodstein
phonon wrote: No matter WHAT I put there, I get an error.
If you will post a complete function that we can try to compile then we will be able to diagnose what the problem is.
If necessary create a simplified version of your actual function that shows the error.
proland
Not to my knowledge, take a look at the interpolate XOP
displayhelptopic "interpolate xop"
EDIT: Apparently Interpolate2 with the /t=2 flag (default) does cubic splines.
phonon
I just edited the earlier post. I think it's just the fact that I thought that if you make a wave or load a wave in a procedure then you can just use it without making a variable.
Incomplete code below:
Function FitAllSets ()
	String listoftempwaves = WaveList("KRDGC*", ";", "")
	String listofdtwaves = Wavelist("Delta*",";","")
	String listofhtrpwrwaves = Wavelist ("PWR*",";","")
	String listofampswaves = Wavelist ("Amps*",";","")
	String listofvoltswaves = Wavelist ("Volts*",";","")
	Variable i
	Variable j
	Variable nsets = ItemsInList(listoftempwaves)
	Variable pwr
	Variable tcon
	Variable tcerr
	Make/N=(nsets) Temp,TempSD,TCon,TCerr
	Variable refNum
	Open /R /MULT=0  /M="Select the Weight (StDev) File" refNum
	LoadWave/A/D/H/J/O/W/K=1/L={0,1,0,0,0} S_fileName                          //This will load waves AbsTemp and SigmaDT
	Wave deltawt
	Wavestats SigmaDT
	Variable npts_SigmaDT = V_npnts
	for (i = 0; i < nsets; i += 1)
		Wave tempwave = $StringFromList(i, listoftempwaves)
		Wave deltawave = $StringFromList(i, listofdtwaves)
		Wave pwrwave = $StringFromList(i, listofhtrpwrwaves)
		Wave ampswave = $StringFromList(i, listofampswaves)
		Wave voltswave = $StringFromList(i, listofvoltswaves)
		Wavestats tempwave
		Temp[i] = V_avg
		TempSD[i] = V_sdev
		for (j = 0; j < npts_SigmaDT; j+=1)
		Wavestats ampswave
		for (j = 0;j < V_npnts; j+= 1)
			Wave ampserr
			Wave voltserr
			Wave pwrwt
			htrpwr = ampswave[j]*voltswave[j]
			ampserr[j] = ampswave[j]*6.6e-4+20e-6
			voltserr[j] = voltswave[j]*1.5e-4+1.5e-3
			htrpwrwt[j] = (sqrt((AmpsErr[j]/ampswave[j])^2+(VoltsErr[j]/voltswave[j])^2))*pwr
		Curvefit/ODR=2 line pwrwave/X=deltatwave /I=1 /W=deltatwt /XW=pwrwt
phonon
Cool. This just might save me lots of time. I would still have to load waves from a file though, either a pre-interpolated one or one that will be interpolated every time the function runs.
proland
You make the waves Temp,TempSD,TCon,TCerr but the function still needs to be told that you intend to do something with them. This is done using wave references.
wave Temp
wave TempSD
wave TCon
wave TCerr
hrodstein
First remove this - it conflicts with your Make statement:
Variable tcon
Variable tcerr
Next add this after the LoadWave statement:
Wave AbsTemp, SigmaDT
Next the wave name here does not agree with the Wave statement above:
Then you've got some inconsistencies between wave declarations and wave assignment statements in the for loop.
In some cases Igor automatically creates wave references but not after LoadWave. Carefully read the following:
including the following subtopic "Automatic Creation of Wave References"
phonon
hrodstein wrote: First remove this - it conflicts with your Make statement:
Variable tcon
Variable tcerr
Oh right. I think those were leftovers.
Oh good, you can do a list like this. That'll save some space.
Thanks a lot.
Now I get the way wave references work.
Sorry for being so clueless.
