Fri, 08/23/2013 - 05:19 am
I just noticed adding the threadsafe keyword to a user function adds about a 20% execution time without even calling the function in a multithreaded use. Is this expected? I guess I had assumed threadsafe was just for the compiler: flag an error if I try to call a non-threadsafe function/operation with multthreading or from within another threadsafe function, but it seems to be affecting execution even if only called in the main thread.
I also thought that the "threadsafe" keyword is just a hint for the compiler.
August 27, 2013 at 04:18 am - Permalink
If you're having trouble observing this, I should concede I only checked with one function, so it's not a comphensive study, although I did check a few combinations of calculation sizes including small and large numbers of points in the implicit loop caused by using a wave assignment statement. You may notice the function I based this one is a direct cut and paste from Peak Functions.ipf, written to go with the Multipeak Fitting package. I started looking at this because I was actually hoping to be able to call the XOP peak functions from MultiPeak Fit with the "multithread" statement. I use them in the HITRAN procedures package, often to calculate a simulated spectrum of thousands of peaks in thousands of output wavelengths. As you'll see from the benchmark (and no real surprise) worrying about a few extra processors on the user defined function is pointless if one has an equivalent XOP function to call. However, I'm assuming the XOP could similarly be sped up by multithreading the wave assignment statement if it were threadsafe, which it is not. I would assume MultiPeak fitting would similarly gain from making the peak functions threadsafe and multithreading the fit, but only if FuncFit can be multithreaded, and I'm not sure if/how one can/would do that. Alternately, if threadsafe were just a compiler directive, then I could whine about why the XOP version peak functions aren't already marked threadsafe. But if it's going to add 20% calculation time and not help speed up MultiPeak Fit, then I can see why the XOP peak functions are not marked as threadsafe even though they could be.
Wave w; Variable x
Variable r= w[0]
variable npts= numpnts(w),i=1
do
if( i>=npts )
break
r += w[i]/((x-w[i+1])^2+w[i+2])
i+=3
while(1)
return r
Threadsafe Function TS_fLorentzianFit(w,x)
Wave w; Variable x
Variable r= w[0]
do
if( i>=npts )
break
i+=3
while(1)
return r
Function BenchMarkit(destsize, numpeaks, functime, tsfunctime, mtfunctime, xoptime)
variable destsize, numpeaks
variable &functime, &tsfunctime, &mtfunctime, &xoptime
make /free /d /n = (destsize) outputwave
make /free /d /n = (3*numpeaks + 1) coefs
coefs[0] = 0
coefs[1,3*numpeaks;3] = enoise(1)
coefs[2,3*numpeaks;3] = enoise(destsize / 2) + destsize / 2
coefs[3,3*numpeaks;3] = exp(gnoise(1) + 1)
variable timerref = StartMSTimer
outputwave = fLorentzianFit(coefs,x)
functime = StopMSTimer(timerref)* 1e-6
outputwave = TS_fLorentzianFit(coefs,x)
tsfunctime = StopMSTimer(timerref)* 1e-6
multithread outputwave = TS_fLorentzianFit(coefs,x)
mtfunctime = StopMSTimer(timerref)* 1e-6
outputwave = LorentzianFit(coefs,x)
xoptime = StopMSTimer(timerref) * 1e-6
Function BenchMarkWrapper(destsize, numpeaks)
variable functime, tsfunctime, mtfunctime, xoptime
print "basic function completed in ", functime, "s"
print "Thread Safe function completed in ", tsfunctime, "s"
print "Multithreaded function completed in ", mtfunctime, "s"
print "XOP function completed in ", xoptime, "s"
and from the command line, the results I get (on a 2 processor netbook running Windows 7) are
basic function completed in 1.21606 s
Thread Safe function completed in 1.50094 s
Multithreaded function completed in 0.791856 s
XOP function completed in 0.0787004 s
•BenchMarkWrapper(10,100000)
basic function completed in 1.13298 s
Thread Safe function completed in 1.39786 s
Multithreaded function completed in 0.771549 s
XOP function completed in 0.0189796 s
August 27, 2013 at 08:23 pm - Permalink
Wave w, yy, xx
multithread yy = w[0]
variable nreps= (numpnts(w) - 1) / 3
variable ii
for(ii = 0 ; ii < nreps ; ii += 1)
multithread yy[] += w[3 * ii + 1]/((xx[p] - w[3 * ii + 2])^2+w[3 * ii + 3])
//edited for correctness
August 28, 2013 at 05:30 pm - Permalink
•BenchMarkWrapper(100000,10) basic function completed in 0.280375 s Thread Safe function completed in 0.340006 s Multithreaded function completed in 0.0754768 s XOP function completed in 0.0195716 s •BenchMarkWrapper(10,100000) basic function completed in 0.251737 s Thread Safe function completed in 0.298765 s Multithreaded function completed in 0.0569062 s XOP function completed in 0.00619713 s
August 28, 2013 at 12:24 pm - Permalink
August 28, 2013 at 05:42 pm - Permalink
August 28, 2013 at 07:43 pm - Permalink
