Plotting and drawing a 3d of multiple curves
Using the following data for example:
Temp. pyrrole Nicotine phenol levoglucosan 3-methyl pyridine
200 4.94E+06 7.10E+07 5.46E+07 3.97E+07 1.54E+06
300 1.39E+07 3.84E+07 5.64E+07 8.47E+07 4.68E+06
400 2.39E+07 6.39E+07 2.28E+07 5.11E+07 2.79E+07
500 1.37E+08 2.75E+08 1.01E+08 1.09E+08 9.01E+07
600 1.09E+07 1.32E+08 1.48E+07 2.42E+07 1.52E+07
700 5.64E+06 8.80E+07 6.58E+06 6.75E+06 4.65E+06
A typical representation of such data is a Waterfall plot. To find out more about this type of plot execute the following command:
DisplayHelpTopic "Waterfall Plots"
If the waterfall plot is not adequate for your requirements you can use Gizmo to plot the data as 3D Path plots. This is a bit more complicated as you would first have to create a triplet-wave corresponding to each compound. Specifically, using the data that you show above you would create for each compound a triplet wave, e.g.,
At this point you need to set the z-column of pyrroleTriplet using a wave assignment or using copy and paste in a table. After you repeat the procedure for each one of your compounds you will be able to create the Gizmo plot. Here is an example of 3 paths from random noise:
I hope this helps,
September 23, 2013 at 12:32 pm - Permalink
Let me try both the waterfall and the gizmo approach then see the outcome.
September 23, 2013 at 10:32 pm - Permalink
