Issue with auto find peaks
Function FindLocalPeaks(data)
wave data // wave containing the trace to analyze
variable nPoints = DimSize(data, 0)
Make /N=(nPoints) /O PeakName = 0 // PeakName is guaranteed to have too many points
// since there can never be as many peaks as there are points in the data
variable i
for (i = 1; i < nPoints - 1; i+=1)
if ((data[i - 1] < data[i]) && (data[i] > data[i+1]))
// the point at index i is a local peak
PeakName[i] = data[i]
offset += 1
EndSo if my csv is:
timeW Intensity
3460473540 350
3460473600 350
3460473660 337
3460473720 320
3460473780 297
3460473840 298
3460473900 1246
3460473960 13776
3460474020 1546
3460474080 1398
3460474140 1097
3460474200 699
3460474260 616
3460474320 427
3460474380 376
3460474440 343
3460474500 327
I want a new wave to be:
3460473540 0
3460473600 0
3460473660 0
3460473720 0
3460473780 0
3460473840 0
3460473900 0
3460473960 13776
3460474020 0
3460474080 0
3460474140 0
3460474200 0
3460474260 0
3460474320 0
3460474380 0
3460474440 0
3460474500 0
And at long datasets, it randomly gives:
3460473540 0
3460473600 0
3460473660 0
3460473720 0
3460473780 0
3460473840 0
3460473900 0
3460473960 6000
3460474020 0
3460474080 0
3460474140 0
3460474200 0
3460474260 0
3460474320 0
3460474380 0
3460474440 0
3460474500 0
September 24, 2013 at 03:28 pm - Permalink
If you want the output wave to have the peak value at at the actual position of the peak max and be zero elsewhere (as shown above) then try the following modification
Two problems that occur to me are that you will miss local maxima at the first and last points in the wave and, if your data is noisey there will be many peaks found that you may not want to consider as peaks.
Edit 9/25:
The function above was edited to correct a syntax error and a few other changes resulted because of that.
Here is a function that does the same thing usint the ?: construct.
Again, with both of these functions, local maxima at the first and last points will be missed. If this is critical, you will need to add code to handle those cases.
September 25, 2013 at 08:50 am - Permalink
The /Q flag suppresses the history report (which takes a lot of execution time) and /M=1 request just the simple stuff be calculated.
September 25, 2013 at 10:06 am - Permalink
September 25, 2013 at 02:56 pm - Permalink
