I spent a few hours testing and found only one minor issue.
The issue that I found relates to the icons that appear in the wave browser widgets in Igor dialogs. Both wave items and data folder items display using the wave icon.
Callisto wrote: I open my files with ...
Normally it remembered the last directory.
But on OSX 10.9 it will go back to my "data" directory every second time I call "open".
I can't reproduce this problem on OS X 10.9 with Igor Pro 6.32A and this code:
Menu"Macros""Test/1", Test()EndFunction Test()String fileFilters = "Data Files (*.txt,*.dat,*.csv):.txt,.dat,.csv;"
fileFilters += "All Files:.*;"Variable refNum = 0Open/R/Z=2/F=fileFilters /M="Looking for a file" refNum
if(refNum != 0)Print S_fileName
Close refNum
endifEnd
Each time I execute the command the Open File dialog shows the same folder as on the previous visit.
Close refNum
endifEnd
I just put this code in procedure window. Executed it once and choose a different folder (it starts with "Documents"). And at the third time I call test() it is back to "Documents". The choosen file is in the 10th subdirectory (counting from root). Under 10.7 and 10.8 I didn't had this problem.
Edit: Even for using a fresh Igor or choosing just a file in a subdirectory of "Documents". (Igor Pro 6.32A)
October 22, 2013 at 07:24 pm - Permalink
October 23, 2013 at 02:47 pm - Permalink
October 24, 2013 at 10:32 am - Permalink
October 24, 2013 at 11:32 am - Permalink
October 25, 2013 at 04:26 pm - Permalink
October 25, 2013 at 05:14 pm - Permalink
