referring to wave in a for loop with incremented numbers
I am trying to refer to waves in a for loop so that I can extract 1 number (cell) from the wave and put into a stats wave.
I can't figure out how to name the wave in the loop using the for loop variable i
The below function works fine. But what I want to do is get rid of the "if" statements that explicitly call out the automatically generated names wave_0, wave_1 ...etc
and use a looped wave name generator something like string expression {wave_i = "wave_" + i_string} where {i_string = sprintf i_string,"%.d", i}
so that I can perform Stats[i] = wave_i[0] on each wave loaded.
This is has stumped me for quite a while now. I am sure it is something simple.
My ultimate goal is to perform statistics on 1000's of files - which is unreasonable for the method I use now.
Any help would be greatly appreciated
#pragma rtGlobals=1 // Use modern global access method.
Function LoadDataSet()
wave Stats
variable i
string i_string
string DataDir, Data
KillWaves/A/Z
for (i=0;i<4;i+=1)
if (i==0) // sprintf uses a space for zero... stupid
I_string = "0"
sprintf i_string,"%.d", i /// converts number into string
DataDir = "Test"+ i_string
Data = DataDir + ":data.txt"
LoadWave/J/D/W/K=0/V={"\t, "," $",0,0}/L={0,0,0,2,1}/p=home/A=wave_ Data
//loads data and automatically names waves "wave_0, wave_1, wave_2,wave_3" from directories Test0,Test1....
//Below pulls data from the first row and puts into a previously created wave Stats (with open table)
if (i==0)
wave wave_0
Stats[i] = wave_0[0]
if (i==1)
wave wave_1
Stats[i] = wave_1[0]
if (i==2)
wave wave_2
Stats[i] = wave_2[0]
if (i==3)
wave wave_3
Stats[i] = wave_3[0]
Added
String WaveNameString
and Added lines for loop
WaveNameString = "wave_" + i_string
wave wave_i = $WaveNameString
Works fine now
wave Stats
variable i, j
string i_string
string DataDir, Data, WaveNameString
KillWaves/A/Z
for (i=0;i<4;i+=1)
I_string = "0"
March 13, 2009 at 09:27 am - Permalink
Cheers, Wolfgang Harneit
March 13, 2009 at 12:05 pm - Permalink
Your case is covered in the topic
DisplayHelpTopic "Wave Accessed Via String Calculated in Function"
March 16, 2009 at 09:42 am - Permalink
