How to sum up specific layers of a 3d wave?
I have a 3d wave witch contains images (512x512) and the names of these images end with to “pos”, “neg”, “prepos” or “preneg”. Now I like to add every image which ends to “pos”, to “neg” or to one of the others.
My first straightforward attempt was the following:
for (ilayer = 0; ilayer < nlayers; ilayer += 1)
//select images with matching criteria take1 = “pos”
if( GrepString(wstackfiles[ilayer], take1) )
addShiftedImage(wcoadd1,wstack,ilayer,0,0)
normalization1+=1
if( GrepString(wstackfiles[ilayer], take2) )
addShiftedImage(wcoadd2,wstack,ilayer,0,0)
normalization2+=1
if( GrepString(wstackfiles[ilayer], take3) && strlen(take3) > 0 )
addShiftedImage(wcoadd3,wstack,ilayer,0,0)
normalization3+=1
if( GrepString(wstackfiles[ilayer], take4) && strlen(take4) > 0 )
addShiftedImage(wcoadd4,wstack,ilayer,0,0)
normalization4+=1
With
Function addShiftedImage(wcoadd1,wstack,ilayer,pdrift,qdrift)
wcoadd1 += wstack[p+pdrift][q+qdrift][ilayer]
But this is slow, for 40 images it takes around 6 seconds. The main time consuming process is the addShiftedImage. Therefore I thougt it should be possible to speed it up by use of MatrixOp and/or MulthiThread.
If I use MatrixOp Funtions, I can speed up by a factor of 3:
MatrixOP/NTHR=0/O/Free temp = wcoadd1 + wstack[][][ilayer]
wcoadd1 = temp
normalization1+=1
MatrixOP/NTHR=0/O/Free temp2 = wcoadd2 + wstack[][][ilayer]
wcoadd2 = temp2
normalization2+=1
MatrixOP/NTHR=0/O/Free temp3 = wcoadd3 + wstack[][][ilayer]
wcoadd3 = temp3
normalization3+=1
MatrixOP/NTHR=0/O/Free temp4 = wcoadd4 + wstack[][][ilayer]
wcoadd4 = temp4
normalization4+=1
Now, I think it should be possible to speed it more up by Multithreading and to start a thread for each “pos”, “neg”…
Is this possible?
-As fas as I understand your code each image can only be one of take1, take2, ...? If yes use one if/endif with elseif.
-For even more speedup you might try to rearrange wstack before so that all take? images are adjacent, then you could use the syntax
of MatrixOp to sum then up in one call.
What is your target layer number?
December 11, 2013 at 02:02 am - Permalink
can I send you an email (22mb) with an example?
December 11, 2013 at 02:57 am - Permalink
rearrangewas a great idea! In total I reduced the compuation time from 6s to around 0.1s!
Thanks a lot,
December 11, 2013 at 04:03 am - Permalink
December 11, 2013 at 04:27 am - Permalink
http://www.igorexchange.com/node/2377#comment-3872
, whoch solved the problem.
December 11, 2013 at 04:57 am - Permalink
glad it works now fast enough.
December 11, 2013 at 05:49 am - Permalink
