GetLastUserMenuInfo
When I have multiple waves from the same folder, It can identify the waves.
However, when I have multiple waves showing in the same graph from different folders, the operation failed.
I read the ihf and it states
The GetLastUserMenuInfo operation sets variables in the local scope to indicate the value of the last selected user-defined menu item.
Is there an operation like GetLastUserMenuInfo but can identify the waves from different folders? if not, is there a code for advancing such function?
Thanks.
Documentation of GetLastUserMenuInfo indicates that S_traceName is set in that case. A graph and trace name uniquely identifies the concerned wave.
January 29, 2014 at 01:48 am - Permalink
I am sorry that I don't understand the meaning of graph's trace contextual menu.
Here is the code which I tried to create a menu called "Show_Tag_All_info" to Tag waves in a graph.
I believe the graph's traces works only if there are all in the same folder.
If I create a graph macro with many waves from different folders, the following code failed to recognize the waves from other folders. (The waves would not show up in the menu)
January 29, 2014 at 09:30 am - Permalink
January 29, 2014 at 10:09 am - Permalink
Thanks for the tip! I did some searches in the forum and found similar code, and it worked.
However, I have one minor issue. In my previous function, I can click on a wave to create a tag for the wave.
With the following code, it just tags all the waves in macro graph. How do I make a code for the tagging selective wave?
I believe it is because of
index +=1
But I dont't know how to modify it.
January 30, 2014 at 09:19 am - Permalink
I've included a new TagAll function just to show how it would work with the re-factored code. But you don't really need it.
NOTE in edit: I just noticed that I left a useless GetLastUserMenuInfo in the TagATrace function.
January 30, 2014 at 10:15 am - Permalink
Great! Thank you for being so patient with me!
January 30, 2014 at 01:32 pm - Permalink
