my IPF file converted to read only?
Not sure how it occurred or how to correct, but I've lost the ability to modify an IPF file of mine due to a read-only status. Igor says I've opened the file as a read only file and it is therefore locked from modification. How do I correct this problem?
Clayton
jtigor
In the lower left corner of the locked procedure window there will be an icon that is a pencil with a diagonal line across it. Click on the icon to make it writable. The error message should have included this fix.
ctmckee
The ipf file property attributes are not read-only and I also made sure and applied that attribute to the Wavemetrics file folder as well. However, when I open the file in Igor I still do not have the ability to edit the file.
As for the symbol in the bottom left corner of the file, it is a black lock. Clicking on it, gives me no option to change.
Clayton
ctmckee
Problem solved. In the security tab of the file properties the permission for the local user was deselected for "write".
Clayton
jtigor
ctmckee wrote: As for the symbol in the bottom left corner of the file, it is a black lock. Clicking on it, gives me no option to change.Clayton
If the same procedure is opened in two simultaneous Igor sessions, the procedure in the last session to be opened with have the lock.
johnweeks
jtigor wrote: If the same procedure is opened in two simultaneous Igor sessions, the procedure in the last session to be opened with have the lock.
We now know that the original problem was caused by the file permissions on his disk.
In fact, you are correct- when Igor opens a procedure file or a plain-text notebook file, it keeps it open. That prevents other applications (or another instance of Igor) from opening the file for writing. This is changing in Igor 7: Igor will open plain-text files, including procedure files, read the text into memory, then close the file. That will allow you to open these files in your favorite text editor or another instance of Igor.
