Generating unique random numbers
Hi all,
I am trying to write a procedure that randomly select waves (for the Y axis) and plot them always against the same wave (for the X axis). My problem starts with generating N unique random numbers (integers). I was generating random numbers and saving them as a wave, but I don't know how to search for a number that is in the wave, just to check if it was already selected.
My idea is this:
<br />
(search for a number, eg. 5)<br />
if found <br />
   generate another random number<br />
else<br />
   save this number<br />
The problem is that I've searched but couldn't find any command to search for numbers inside a wave.
Cheers
johnweeks
This function:
Function randomize(nn)
	Variable nn
	Make/O/N=(nn) W_random
	Make/N=(nn)/FREE random=enoise(1)
	MakeIndex random, W_random
will create a wave called "W_random" containing the integers [0...nn-1] in pseudo-random order.
raponzoni
This is perfect and very practical, but it is generating a random number until the limit nn. For example, if I make it generate 20 random numbers it is generating random numbers til the number 20.
In my code I can define the random limit by changing the value (this case X) at the function enoise(X).
I tried the same on your code and changed it to 1000, and it still generates random numbers between 0 and NN.
I would like to define the limit, is there any chance to do that in your code?
Ty
daggaz
Johnweeks' code as written wont allow you to change the range of the 'random number' that is in the output wave, because it is just parsing the actual random numbers (of any range) into integers based on how large they are compared to each other. So all you are getting, as he said, is a pseudo-random ordering of a set of continuous integers (such a set is definitely not random). This is all from the use of the MakeIndex command.
(note, you can right click commands inside of IgorPro and get the helpfile!)
The following function is one way to get what you are asking for I believe
#pragma rtGlobals=3		// Use modern global access method and strict wave access.
Function Random_wave(nn,range)
variable nn,range
variable i
for(i=0; i<nn; i+=1)
// next line makes the range -0.4999 to 0.4999, shifts it to .0001 to 0.9999, and then scales it up to approx. 0 to range
   W_random[i] = (enoise(.4999)+0.5)*range
You can add in floor,ceiling,or round commands if you want to output integers instead of decimals, and you could add another layer to call this multiple times if you wanted to make say, 100 such waves, as well as writing in the functionality to have it automatically display the graphs you want.
raponzoni
Thanks for your attention...
Yes, the code you wrote is working fine, i just replaced:
<br />
W_random[i] = (enoise(.4999)+0.5)*range<br />
for
<br />
W_random[i] = (abs(round(range)))<br />
because I need always an integer value and positive!
However, the code has the same problem I have on my own code, it is generating random positive integer values, but not unique values. For exemple, the number 5 could not be in the W_random wave 2 times...
So, my question is, is there any flags to sinalize to generate unique values?
Thanks so much again
raponzoni
Thanks for your time S.r.chinn
Basically, I have around 300 waves where a few should be plotted randomly (with no repetitions). In other words I would like to Igor procedure generate N random plots from those 300 waves.
I need to work with that, almost everyday, so, if I could do a procedure to help me with that my life will be so much easier...
My first idea was generate a wave with the chosen random numbers, then I will find a way to link those numbers with my waves (since they all are numbered on name).
If you have any idea that you think that could be applied here, please share!
Thanks so much
daggaz
You are running into problems when you limit your set to unique values only, because the larger the set compared to the allowed range, the less random the final result will be. Not sure if that's a problem for you or not.. EDIT: nm, i see where you are going with this.
This will work for you I think. Note that (range) must be equal to or greater than (nn). Cant be bothered to code in the check for that:
variable nn,range
variable i,target
Make/o/n=(range) W_values = p
   target = floor((enoise(.4999)+0.5)*(range)) // return a random integer value from 0 to (range - 1)
   W_random[i] = W_values[target]
   DeletePoints target,1,W_values
   range -= 1
killwaves/z W_values
Of course, if you have 300 files and you only need 20 of them randomly selected, you could just use Johnweeks original and much shorter/simpler code, set nn = 300, and then take the first twenty entries.
raponzoni
Thanks so much for this daggaz... it is working fine for me!
Just one last issue, linked with the final plotting command. When I type this command at the command line works and the graph is plotted:
<br />
Display polyDiff_Y102_map_1 vs xAxis<br />
The final issue is, the name of the wave to be plotted is inside a string. In this exemple VAR="polyDiff_Y102_map_1"
I tryed just replace polyDiff_Y102_map_1 for the variable, but didn't work! Is there any way to refer a wave using a variable?
Thanks so much for the help from you all !
patarroyo
I know this an old thread, but the function that John Weeks provided worked perfectly for something I needed. Thanks!
s.r.chinn
This is the thread that refuses to die :) Here is a more concise (and perhaps somewhat obscure) method:
function GetRandomIndices(Nwaves, Nsamples)
	variable Nwaves, Nsamples
	Make/O/N=(Nwaves) srcWave=p
	StatsSample /N=(Nsamples) srcWave
	WAVE W_Sampled // created by StatsSample
The wave W_Sampled contains your wave indices (random distinct integers) from the number of total waves. If desired, this function could be changed to a wave reference function using the /WAVE flag. Also, the random order of the output indices can easily be sorted if necessary. For details, see
DisplayHelpTopic "StatsSample"
