FFT Phase Spectra Question
Greetings,
I have a couple of what may be relatively naive questions.
I have data from which I would like to extract the phase however when performing an FFT, the x-values of the resultant phase spectrum do not include the frequency of the sine wave. If I effectively average the two data points around the frequency, I obtain the correct phase. I haven't had this problem with my magnitude spectra and I am not certain if this is typical. The following is an example:
Make/O/N=10000 w0 SetScale/I x 0,10,"s", w0 w0 = sin(4*pi*x+pi/2) FFT/OUT=5/DEST=w0_FFT/RP=[0,4749] w0;DelayUpdate display w0 display w0_FFT
In the above example, the resultant phase spectrum has data points with x-values of 1.8945 and 2.1051 (on either side of the sine wave frequency of 2 Hz). When I average the phases at these two x-values (-1.5733 and 1.5673, respectively), I obtain the expected phase of zero for this sine wave. Is it typical to need to find a midpoint to obtain my phase?
My second question is whether I can unwrap the phase spectrum I've generated. I haven't had luck using the command "Unwrap 2*pi, w0_FFT", which I've used successfully with the Hilbert Transform.
Thank you in advance for your help!
There are a few issues one can comment on regarding your setup. The first is that your are using /RP yet your range does not describe full cycles. I suggest you start by changing the FFT command to:
 FFT/DEST=w0_FFT/rp=[0,4749] w0
Now plot the real and imaginary parts of w0_fft
Next, replace your /RP range so that it covers full cycles, e.g.,
FFT/DEST=w0_FFT/rp=[0,4999] w0
and observe the differences in the calculated phase. In general, when you encounter edge effects you should think of window functions so see /WINF flag of FFT.
I'm not clear about the pi/2 phase. Why not use a cosine instead?
Finally, if you are going to look for accuracy, especially when adding pi/2, it might help to use a DP wave so change your Make to Make/D.
Igor wrote: There are a few issues one can comment on regarding your setup. The first is that your are using /RP yet your range does not describe full cycles. I suggest you start by changing the FFT command to:
Thank you so much for your reply. You were indeed correct that the FFT range was causing my problem with the phase spectrum matching the sine wave frequency. When I corrected that, I was able to obtain the correct phase at the corresponding frequency. As for why I used a sine wave or added pi/2, I was just trying a few sample calculations to ensure I could determine the appropriate phase using the FFT (so not something I'll be using later).
Is there a benefit to calculating the phase manually, rather than using the FFT phase spectrum output (/OUT=5)?
With respect to the second question about unwrapping the result, do you know how this could be best achieved? I'm interested in the phase shift between a stimulus wave and a response wave and the 'lagging' response wave may fall sufficiently behind to cause the wrapping to underestimate the shift.
Thank you once again and hope to hear from you soon.
I calculated the complex FFT so I can look at both real and imaginary components. In this application I prefer to look at complex numbers this way. The phase (being mod 2*pi) is less helpful.
I am not following the details of your application. In your example I only saw FFT of one wave so I do not immediately see how that relates to computing a response time from two separate waves. There are infinitely many ways you can have a "response" to a "stimulus" and in each case you would have to write different code to extract the time difference. Since I do not know anything about the shapes of your stimulus wave or response wave I can't really comment any further.
I think it would be best if you would post a new thread that focuses on that issue. Describing your two waves (or even plotting an example) might also be good.
