Is there a way to remove the unnecessary points from a column of a table?
I used the Peak Areas.ipf to find the maximums and minimums of a wave. I then placed the the W_MaxKnots and the W_MinKnots into a table. It show the values I need, but there are many unnecessary points in between. I was hoping to find a way to remove certain points from the table so that I am left with only the values I need. If anyone has any suggestions, that would be fantastic.
Thank you!
But bear in mind that you may be breaking the functionality of the rest of the Peak Areas.ipf if you change the data out from under it like that.
I suggest copying the waves. Or just use W_PkX1 and W_PkX2, which are derived from the knots. See my reply at
http://www.igorexchange.com/node/5875
July 17, 2014 at 09:59 am - Permalink
July 17, 2014 at 11:30 am - Permalink
Have you looked at http://www.igorexchange.com/node/5875 ?
July 17, 2014 at 12:47 pm - Permalink
July 17, 2014 at 12:59 pm - Permalink
