SetVariable with string
With the Prep4AnalyseGBC function, my aim is to allow the user to create the definition for a string variable (sID) which is then passed to a series of other routines that I have not shown. My problem is with the SetVariable operation. When I enter text into the control panel, my expectation is that this will become the definition for sID. The information that is available in the igor manual (page III-377) about using SetVariable in this way implies to me that the text entered to the control panel should be passed to the parameter varStr in my action procedure, Prep4AnalyseGBC_svWaveID.
However, this is not happening, because the procedure fails at run time and sID comes out as a null string. Can anyone elaborate a little on how SetVariable is supposed to work in this case or point me to a few pages in the manual where more information is available?
Structure strAnalyseGBC String sID EndStructure Function Prep4AnalyseGBC()//(vVoltageAmplitude4TPParameters, sFirstDF, sLastDF) //Variable vVoltageAmplitude4TPParameters //String sFirstDF, sLastDF NewDataFolder/O root:tmp_PauseforPrepDF String/G root:tmp_PauseforPrepDF:sID = "" //STRUCT strAnalyseGBC Prep4 DoWindow/K tmp_PauseforPrep NewPanel/K=2 /W=(90,300,420,460)/N=tmp_PauseforPrep as "Enter wave info" SetVariable svWaveID, title="Wave ID", fsize=14, pos={50,25}, size={150,50}, value=_STR:"", proc=Prep4AnalyseGBC_svWaveID PauseForUser tmp_PauseforPrep SVAR sID_G = root:tmp_PauseforPrep:sID //sID receives an alternative designation as a global string variable. String sID = sID_G //sID as a global variable is copied to a local string. KillDataFolder root:tmp_PauseforPrep //Print Prep4.sID Print sID End Function Prep4AnalyseGBC_svWaveID (svWaveID, varNum, varStr, varName) : SetVariableControl String svWaveID, varStr, varName Variable varNum //STRUCT strAnalyseGBC Prep4_svWaveID String/G root:tmp_PauseforPrepDF:sID = varStr //Prep4_svWaveID.sID = varStr DoWindow/K tmp_PauseforPrep End
If you want to store the value in a global variable you need to write:
value=root:tmp_PauseforPrep:sID
However using the internal storage is better because it avoids the need to create a global variable.
July 28, 2014 at 06:35 pm - Permalink
- You don't need an action procedure just to pass the value to some global string. You should tell
SetVariablewhich string to use upon its creation and the variable control will always automatically update. That's what thevalueparameter is for.- With the newer Igor versions it became even more unfavorable to use global variables for this. Better not hardcode these ugly things into your code and clutter your experiment. You can use
value=_STR:stuffto attach this stuff directly to the particular control (i.e., its window- and even control-specific). Extract the value usingControlInfoonly when needed (opposed to having the stuff lying around all the time.Edit: Ooops, too slow this time ... OK, here's a bonus comment:
It seems that you are working with folders (a lot?). You might want to look into data folder references (DFREFs) before its too late to clean up all the clutter.
July 28, 2014 at 07:01 pm - Permalink
i.e. whatever is entered into the text box in the panel (tmp=PauseforPrep) that appears.
July 30, 2014 at 09:08 am - Permalink
That's because you are killing the SetVariable control, by killing the panel, before you call ControlInfo.
Here is a way to achieve what you want.
July 30, 2014 at 09:36 am - Permalink
August 1, 2014 at 09:48 am - Permalink
There are two forms for the action procedure. The form that takes a ctrlName parameter is antiquated. The form that takes a reference to a structure is recommended.
August 1, 2014 at 12:57 pm - Permalink
August 6, 2014 at 10:54 am - Permalink
That's because your function returns before the Printf statement.
This statement makes no sense because you have no control named vDoNotMeasureArea:
Same for vMeasureArea.
You don't need to call ControlInfo for a button. The mere fact that your button action procedure was called means that the button was clicked.
August 6, 2014 at 12:42 pm - Permalink
August 7, 2014 at 02:40 am - Permalink
PauseForUserstatement. You are using sGraphName as the target, and to cite the manualAugust 7, 2014 at 06:27 am - Permalink
But I should be able to click between the two windows without a problem - that is what is implied by the statement you cite from the manual. What happens now is that I can click on either window once execution pauses, but as soon as I click on the 'target window' I get stuck on it and cannot click on the panel (which seems to be locked in the background).
August 7, 2014 at 01:00 pm - Permalink
August 11, 2014 at 03:26 am - Permalink
