Burn-in annotation on TIF's
I load existing TIF images to annotate them in Igor using
SetDrawEnv
followed by e.g.
DrawText
or
DrawLine
Using then
ImageSave
does not save the annotation. I understand why but is there any possibility to do a "burn-in"?
KurtB
I think you can use Edit - Export Graphics...
This copies the window to the clipboard, with annotations (at least it did for me when I tried just now).
Alternatively there is File - Save Graphics...
Hope this helps.
Regards,
Kurt
ChrLie
Thanks Kurt (sorry for the late reply!).
I didn't know about "Export Graphics" and the clipboard option, but I want to do this programmatically (adding scale bar information to a bunch of microscopy images), so pasting the image somewhere will be the problem.
With "Save Graphics" I incorrectly thought I don't preserve the image dimensions but a preceding
ModifyGraph margin=-1
does the trick.
ChrLie
does the trick.
Well, actually no it doesn't.
To be more specific: Considering the following (example-) annotation function:
function AnnotationTest(width)
	variable width
	variable height = round(width*3/4)
        //make image
	Make/O/W/U/N=(width, height) M_Image = abs(enoise(65535))
	Duplicate/FREE/O M_Image ScaleBar
	//Make scale bar 10% of image height
	Redimension/N=(width, round(height/10), -1) ScaleBar
	ScaleBar = 0
	variable ScaleHeight = DimSize(ScaleBar, 1)
	variable textheight = (height+ScaleHeight/2)/(height+ScaleHeight)
	Concatenate/O/NP=1 {M_Image,ScaleBar}, M_ImageScaled
	NewImage/K=1 M_ImageScaled
	// add some text
	SetDrawEnv textrgb= (65535,65535,65535),textxjust= 1,textyjust= 1,fstyle= 2, fname ="Arial", fsize = round(ScaleHeight*0.3)
	DrawText 0.5, TextHeight ,"...noisy image...."
	// add e.g. scale bar, magnification etc…..
and executing:
AnnotationTest(1024)
SavePICT/O/E=-7 as "Annotated.TIF"
saves an images with a width of 1052 pixel instead of 1024 to disk. I tried playing with the /RES and /B flag, but unsuccessfully. Is there any way to annotate but not changing the image width upon saving? ImageSave does it, but then the text is gone.
EDIT:
I just realize this seems to be more an issue related to
NewImage
….. but still makes me wonder how to get an annotated image with the exact image width.
