commenting multiple lines of code
Is there a way to comment out multiple lines of code in IGOR? Similar to the right click comment all in MATLAB?
andyfaff
THere isn't a keyboard shortcut and you can't do multiline comments a la c:
comment
but you can select the lines you want to comment and Edit->Commentize
jjweimer
andyfaff wrote: ...but you can select the lines you want to comment and Edit->Commentize
... and on the Mac you can map the Commentize / Decommentize commands directly to your preferred keystrokes through the Keyboard Preference pane.
EDIT: See the posting at this link ... http://www.igorexchange.com/node/2543
In reply to by ysspatil
azeigle
Great tip, thanks!  Note that "Alt+e, o" simply opens the edit menu and selects "Commentize".  So it's not necessary to memorize the shortcut as long as you know where to find it.
johnweeks
In Igor 8, cmd-/ or ctrl-/ will commentize selected lines, and cmd-\ or ctrl-\ decommentizes. That would be cmd on Mac, ctrl on Windows.
