function like accumarray or bincount
function map()
make/O/C/N=(128,128) gauss_wave = 0
make/O/N=(128,128) map_wave = 0
gauss_wave += cmplx(exp(-(x^2+y^2)/8192), 1-exp(-(x^2+y^2)/8192))
map_wave = round(sqrt(x^2+y^2))
make/O/C/N=(wavemax(map_wave)+1) accumarray
variable i,j, index
for(i=0; i<128; i+=1)
for(j=0; j<128; j+=1)
accumarray[map_wave[i][j]] = gauss_wave[i][j]
Is there any way to use MatrixOp or otherwise speed this up?
Before we start optimizing the code. Does the code really do what you want?
The problem is symmetrically in i and j so I would have expected something like
as you otherwise overwrite values in the accumulation array.
April 13, 2017 at 08:04 am - Permalink
April 13, 2017 at 04:05 pm - Permalink
Using the MSTimer, this code takes about ~13 ms. I don't have access to my matlab setup right now but I believe the code runs in less than 1 ms. I will double check and get back.
April 14, 2017 at 02:09 pm - Permalink
Would this improve with some other implicit indexing trick (by example admittedly off the top of my head ...)?
April 14, 2017 at 03:23 pm - Permalink
I'm not sure about threading but it should work better with MatrixOP WaveMap(). What may not be so obvious is that waveMap() works with 1D, e.g.,
In the case of the code above, there is no obvious reason why one can't execute:
or possibly just redimension the original waves (faster).
April 18, 2017 at 05:44 pm - Permalink
