I want to re-scale the "Scaled Dimensional index" of a two dimensional wave. For this I need to know the 'Scaled Dimension Index' of particular data point from it's row index and column index.
Here is some example code to get you started for your particular needs:
function foo()// make a test waveMake/O/N=(13, 9) wave0
setscale/Ix, -0.6, 0.6,"" wave0
setscale/Iy, -4.0, 4.0,"" wave0
wave0 = Gauss(x, 0, 0.2, y, 0, 2)endfunction bar(rowIndex, columnIndex)// test the function belowvariable rowIndex, columnIndex
WAVE wave0
Wave wOut = ScaledDimIndex(wave0,rowIndex, columnIndex)print wOut
endfunction/WAVE ScaledDimIndex( InputWave, rowIndex, columnIndex)// returns the x and y scaled dimension indices as a two-element wavewave InputWave
make/O/N=2 wOut
variable xx = DimOffset(InputWave,0)+DimDelta(InputWave,0)*rowIndex
variable yy = DimOffset(InputWave,1)+DimDelta(inputWave,1)*columnIndex
wOut = { xx, yy }return wOut
When testing this, you should see:
•bar(1, 1)
wOut[0]= {-0.5,-3}
as the {x, y} values for point indices [1][1].
Note the core functions DimOffset and DimDelta for use with multidimensional waves.
for each dimension that you need the scaled position (0 and 1 for rows and columns respectively)
I would normally suggest using SetScale to "re-scale" the dimensions of a wave, but you don't need to know its current settings to do that, so I'm not sure that's quite what you're asking for.
@s.r.chinn and @ikonen - Thank you very much! You have given the exact answer, I was looking for. Part of my problem is now solved. For quick checks, I am using DimOffset and DimDelta. But I am writing a macro to process several waves, where chinn's elaboration is very helpful. Thanks!!!
I need to know the scaled dimension value first to determine the re-scale value. I am writing a macro, and I need to call it.
December 12, 2012 at 06:34 am - Permalink
December 12, 2012 at 06:39 am - Permalink
December 12, 2012 at 07:13 am - Permalink
December 12, 2012 at 08:40 am - Permalink
