Panel Control to Draw or Edit Marker Waves
This uses a panel to create, edit, and clear a drawing wave. The waves are created in the current data folder and have the names drawwaveY and drawwaveX.
// a static constant to set the panel name
StrConstant k_panelname = "WaveDrawEdit"
// change this to set your desired marker style to create and edit the marker wave
Function set_DrawMarkerStyle(frontimgwin)
string frontimgwin
// set your desired marker style here
ModifyGraph/W=$frontimgwin mode=3,marker=8,msize=5,mrkThick=2
// call this to create the panel
Function show_DrawControlPanel() : Panel
NewPanel/W=(50,50,250,100)/N=$k_panelname as "Wave Draw/Edit"
ModifyPanel/W=$k_panelname fixedSize=1,noEdit=1
Button bDrawControl,pos={15,10},size={50,20}, fSize=14, userdata(draw)="start",proc=ButtonProc,title="Start"
Button bEdit,pos={70,10},size={50,20},fSize=14,proc=ButtonProc,title="Edit",disable=2
Button bClear,pos={130,10},size={50,20},fSize=14,proc=ButtonProc,title="Clear",disable=2
// do or end the drawing or editing
Function do_Draw()
string udata, frontimgwin
udata = GetUserData(k_panelname,"bDrawControl","draw")
frontimgwin = WinName(0,1,1)
strswitch(udata)
case "start":
Button bDrawControl, win=$k_panelname, userdata(draw)="end", title="End..."
Button bEdit, win=$k_panelname, disable=2
Button bClear, win=$k_panelname, disable=2
// the drawing waves are created in the current data folder
make/N=0/O drawwaveX, drawwaveY
SetDrawLayer/W=$frontimgwin ProgFront
GraphWaveDraw/W=$frontimgwin/L/T/O drawwaveY, drawwaveX
break
case "end":
GraphWaveEdit/W=$frontimgwin/T=1 drawwaveY
GraphNormal/W=$frontimgwin
SetDrawLayer/W=$frontimgwin UserFront
Button bDrawControl, win=$k_panelname, userdata(draw)="start", title="Start"
Button bEdit, win=$k_panelname, disable=0
Button bClear, win=$k_panelname, disable=0
break
endswitch
// edit the drawing
Function do_Edit()
string frontimgwin = WinName(0,1,1)
GraphWaveEdit/T=1/W=$frontimgwin drawwaveY
// clear the drawing
Function do_Clear()
RemoveFromGraph/W=$frontimgwin/Z drawwaveY
// button control
Function ButtonProc(ba) : ButtonControl
STRUCT WMButtonAction &ba
switch( ba.eventCode )
case 2: // mouse up
strswitch(ba.ctrlName)
case "bDrawControl":
do_draw()
break
case "bEdit":
do_edit()
break
case "bClear":
do_clear()
break
endswitch
break
break
endswitch
With one clever change, the system now keeps the markers for the drawing also when clicking the End... button. It first toggles to GraphWaveEdit/T=1, then toggles to GraphNormal.
April 24, 2020 at 08:43 am - Permalink
