Standard Deviation calculattion
Could someone tell me how Igor Pro can calculate the SD from values given in a wave? For example a certain quantity has been measured more than once and we have 2 values for it e.g. 3.15 and 3.28. How the SD can be calculated for these 2 values using Igor Pro (similarly to Excel).
Thank you in advance
Answer to how to calculate standard deviation in Igor Pro. If your values are in wave0 execute
wavestats wave0
. Standard deviation is stored in the variable V_sdev. In answer to whether you should do this for just two values... I cannot say.
While a standard deviation from two values can be calculated (just like an "average" can be calculated for 1 value), it's fairly meaningless. Standard deviation, conceptually, is where ~68% of the data will lie if the data are Gaussian-distributed. So you need several data points to build up the statistics to understand where that ~68% envelope is. So you can do it, it just won't really mean much.
Igor also has a quick way to see the standard deviation of a wave in the data browser. On the top right of the data browser, there is a field to change some display options. Make sure the 'info' check-box is selected. There is a small 'i' box which, when clicked, can be switched to a sum symbol. In this state, the bottom text field shows various calculations (a bit like instant wavestats) for the currently selected wave, including the standard deviation.
Is there a simple command, such as
print mean(my wave)
to compute the standard deviation and for instance attribute this value to a variable su ch:
myvariable=mean(my wave)
thank you
tijead wrote: Is there a simple command, such as
print mean(my wave)
thank you
You can use
Variance
For example, try:
make/O/D/N=1000 myWave=gnoise(2)
print sqrt(variance(myWave))
Hope this helps,
Kurt
