Could someone tell me how Igor Pro can calculate the SD from values given in a wave? For example a certain quantity has been measured more than once and we have 2 values for it e.g. 3.15 and 3.28. How the SD can be calculated for these 2 values using Igor Pro (similarly to Excel).
Thank you in advance
August 21, 2014 at 04:35 am - Permalink
August 21, 2014 at 12:38 pm - Permalink
August 21, 2014 at 07:13 pm - Permalink
to compute the standard deviation and for instance attribute this value to a variable su ch:
thank you
April 10, 2017 at 02:23 am - Permalink
You can use
For example, try:
Hope this helps,
Kurt
April 10, 2017 at 03:39 am - Permalink
April 10, 2017 at 04:03 am - Permalink
