Loop causing inexlicably "Index out of range for wave CU_AA"-error
PeterR
Fri, 10/03/2014 - 05:02 pm
I have encountered a strange problem that I can not figure out:
The following code should be used to compare a List of amino acids with a user-defined input sequence. The found values shall be written to a wave CU_AA, which should be enlarged by 1 whenever a new matching amino acid is found.
for(c=0;c<(numpnts(AA_OLC));c+=1)
TransientActiveAA = AA_OLC [c]
// Compare Transient active AA and active AA:
if(cmpstr(TransientActiveAA,ActiveAA)==0)
// If equal
Wave /T CU_AA
if(waveexists(CU_AA)==0)
Make /O /T /N=1 CU_AA
CU_AA [0] = Codons [c]
Redimension /N=(numpnts(CU_AA)+1) CU_AA
Variable test = numpnts(CU_AA)
CU_AA [test] = TheValue
On the second run of the loop, the program stops - error code: "Index out of range for wave CU_AA"
This I cannot understand, since the index normally changes from 1 (
Make command
) to 2 (Redimension command
).Where is the bug?
Thanks in advance for any help!
Regards,
Peter
CU_AA[test] = TheValue
It should be:
CU_AA[test-1] = TheValue
A neater way to do it is:
CU_AA[numPoints] = {TheValue} // Extend wave with new value
October 3, 2014 at 06:52 pm - Permalink
October 4, 2014 at 01:50 am - Permalink
Redimension
in the code, I would add some quadratic growth strategy to the code.E.g:
for(...)
Wave/Z/T wv
if(!WaveExists(wv))
Make/T/N=128 wv
idx = 0
oldSize = DimSize(wv, 0)
if(idx >= oldSize)
Redimension/N=(oldSize * 2) wv
idx = oldSize
wv[idx] = theValueYouWantToStore
idx += 1
// After you are done, remove excess rows
Redimension/N=(idx) wv
October 4, 2014 at 09:27 am - Permalink
