making a video using an array of images
I am very new at Igor and I am going to use it in my PhD research. My supervisor asked for me to create an algorithm that will use image files (ie jpg) in order to create a movie. I tried the bellow, but apparently is not correct. Could anyone suggest anything? Thank you.
Function A()
Newpath/O IgorSpace, "C:\Users\Public\Documents\Wavemetrics\IgorSpace" //Here I have my satellite images
print indexedDir(IgorSpace,0,0)
print indexedfile(IgorSpace, -1, ".jpg")
imageload /P=IgorSpace /T=jpg "1235.jpg" //I don't know if this command is useful
LoadPICT /P=IgorSpace "1235.jpg" sat1 //I understood that I have to load the image into a wave, for example 'sat1' here
newmovie /F=1 /O /P=IgorSpace /PICT=sat1 //finally I write this command to use the previous loaded image
closemovie
0. Load the first image using ImageLoad and display in a graph window using NewImage/S=0. This will give you a full frame display of the image with no axes.
1. NewMovie -- you need to create a new movie at the start of the process and associate it with the image window.
2. Loop through the images:
2.1 Load each image using ImageLoad and overwrite the wave that is currently displayed.
2.2 add the frame to the movie using AddMovieFrame
3. Close the movie.
In step 2 you should probably use IndexedFile() and not IndexedDIR(). Note also that the resulting order may be different from what you expect so if the order of frames is important you have to make sure that you are loading the files in the required order.
You may want to examine a code example in File Menu->Example Experiments->Movies & Audio->FM Modulation Movie.
I hope this helps,
October 23, 2014 at 11:24 am - Permalink
I tried tis one:
imageload /O/P=IgorSpace /T=jpg /S=0
newimage /N=SatSet /S=0
but newimage command requires a wave reference.
I cannot understand where the image is loaded (is there any wave or sth like that?) and which is the name that I should use as a reference to the newimage command?
October 24, 2014 at 06:36 am - Permalink
The nature of your comments suggest that you might benefit from going through the Getting Started Tutorial (if you have not done so already).
You do not need /S in Imageload because you seem to load jpeg files and so multiple/stacked images are not supported.
After you execute ImageLoad you can execute:
or simply look in the Data Browser window to find out what waves where created. If you are not familiar with the Data Browser window it may be a good idea to get acquainted with it now. You will find it under Data Menu->Data Browser. You can also execute on the command line:
Note that ImageLoad tends to create waves based on the name of the image file. For example, if you load image.jpg then chances are that your wave name will be "image.jpg". A wave name containing a '.' is considered a liberal name and as such requires that you pass it to subsequent commands using single quotes as in 'image.jpg'. My personal preference is to rename the wave as soon as possible so I do not have to type silly quotes. In function code I use:
Here I returned to my earlier suggestion that you start by loading and displaying a first image. Set the name of that wave to "firstImageWave" and in your loop overwrite that wave with the new images.
October 24, 2014 at 10:11 am - Permalink
I use the command below, but when I run my function, a message says that a picture name expected. The name of the picture is 1235.jpg and it also exists in data browser. What should be wrong here?
newmovie /F=1/P=IgorSpace/PICT='1235.jpg'
Thank you again and I apologize for my very newbie questions.
October 27, 2014 at 08:46 am - Permalink
I suggested that you start by loading the first image and then displaying it as a graph. Only then you should execute the newmovie command. In that case, when you execute the newmovie command you have an image displayed in a front graph so you do not need the /PICT flag. So your code will look something like:
October 27, 2014 at 10:04 am - Permalink
October 28, 2014 at 09:03 am - Permalink
After the afore-mentioned instructions I managed to create this code that creates a video using images:
The problem is that when I try to run this program, a message says "expected wave name" refering to the command newimage. I have declared the wave w, but i cannot understand why a message like that appears. Additionally, the command print w inside for loop gives a null wave instead of a wave that contains the images for video.
Are there any ideas?
November 10, 2014 at 07:54 am - Permalink
at that time fileListString is not a list anymore and the index i > 0 does not exist.
Something like this should probably do it:
November 10, 2014 at 08:37 am - Permalink
November 11, 2014 at 02:16 am - Permalink
In reply to by ChrLie
I found this forum relevant to make a video of my images that I loaded as image file in jpg format. However it fails to run this code. Basically I created a folder called IgorSpace and loaded every images in it on my experiment file. Whenever I run the code, it asks me select a folder, however after selecting the folder that has images, it does not match the selection and says "attempted to access a null string variable". A quick search help topic says that is StringFromList should have a list of text items. I created a table of textwave with names of all images but that did not work too. I must have misunderstood some basic stuff. Can anyone suggest me?
Thank you in advance !
August 23, 2020 at 09:56 pm - Permalink
In reply to Hi, I found this forum… by TRK
1. folder does not have to have a specific name, the code asks you to select it
2. you don't need to load images into experiment, the code does that
3. are you executing Igor_movie_from_picture("jpg")?
August 24, 2020 at 12:25 am - Permalink
In reply to 1. folder does not have to… by tony
Thanks Tony for the reply !
I made attempts with Igor_movie_from_picture(jpg), Igor_movie_from_picture(fileStr) and Igor_movie_from_picture() but could not succeed yet.
August 24, 2020 at 07:45 am - Permalink
In reply to Thanks Tony for the reply ! … by TRK
try
with the quotes and the "."
August 24, 2020 at 07:50 am - Permalink
In reply to try Igor_movie_from… by tony
Well, now the code gets executed but when I select the folder that has jpg files, it returns an error saying that unsupported image format. But it only creates a Tempmovie file with a graph on my experiment file.
Also what is "." doing in the execution command. I was thinking of something $ for the string.
August 24, 2020 at 08:07 am - Permalink
filestring, the input to the function, is a string that is used as a parameter for the IndexedFile function.
to see what IndexedFile is expecting to find in the string.
filestring is later used with ImageLoad to specify the file type. Here it must be "jpeg", not ".jpg". So try that instead.
August 24, 2020 at 08:15 am - Permalink
Thanks Tony, well this time it displays this error. "While executing CloseMovie, the following error occurred: No movie"
Looking for the explanation on close movie did not help to fix this
August 24, 2020 at 08:38 am - Permalink
if there is no list of files printed to history and you weren't prompted to save a movie file, indexedfile is not listing the jpegs.
for a quick solution, try hardwiring the code for jpegs, something like this:
August 24, 2020 at 09:24 am - Permalink
