Normalization
Dear all
I need some help to normalize to unit the waves a table.There are 40 waves in total.
Is there any idea?
Thank you in advance
Giannis
jjweimer
Giannis wrote: Dear all
Is there any idea?
Would either of these functions be of use?
Function NormalizeByHeight(wname)
      wave wname
      WaveStats/Q wname
      wname/=V_max
Function NormalizeByArea(wname)
     wave wname
     duplicate/O wname twave
     integrate twave
     WaveStats/Q twave
     wname/=V_max
     killwaves/Z twave
You can call them from within a larger function that loops through the waves you want to process.
Igor
How about:
MatrixOP/O outWave=Normalize(inWave)
or
MatrixOP/O outWave=NormalizeCols(inWave)
or if you want to normalize to the maximum value:
MatrixOP/O outWave=inWave/maxVal(inWave)
ChrLie
Igor wrote: How about:
or
Sorry for digging old threads out ..... I just got puzzled, because I expected the outcome of outwave1 and outwave2 in the following example to be the same:
function NormalizeTest()
	Make/O/FREE w = {1, 2, 3}
	Duplicate/O/FREE w outwave1, outwave2
	Wavestats/Q w
	outwave1 /= V_Sum
	Print outwave1
	MatrixOP/O outwave2 = Normalize(w)
	Print outwave2
It not quite clear to me to what value "Normalize(w)" actually normalizes.
Cheers
Christian
johnweeks
ChrLie wrote: Sorry for digging old threads out ..... I just got puzzled, because I expected the outcome of outwave1 and outwave2 in the following example to be the same:
	Wavestats/Q w
	outwave1 /= V_Sum
	Print outwave1
	Print outwave2
Experiment confirms that MatrixOp Normalize normalizes a wave by its magnitude (that is, the square root of the sum of squares). I confirmed this by doing this:
Make junk=enoise(1)+3
duplicate junk, junk1
junk1 = junk^2
Variable ss = sqrt(sum(junk1))
junk1 = junk/ss
The result is the same as the output of MatrixOp Normalize.
Igor
Hello Christian,
The documentation for MatrixOP Normalize() explicitly states:
"Normalization is such that the returned wave should have a unity magnitude..."
ChrLie
Hi John and AG,
thanks for pointing this out. I did look into the manual, but I missunderstood the term "unity magnitude".
C
