error: expected wave name----help
I wrote a procedure to deal with my experiment data.
When running it, the error message "expected wave name" popped up.
I attached the file and error message below.
Could anyone take a look and help me out.
Felix
#pragma rtGlobals=3		// Use modern global access method and strict wave access.
function experiment20151116_RBS_Chi_Cal(r1,c1,c2,c3,c4,c5)
wave r1, c1, c2, c3, c4, c5
make /O/N=5 chi_all
string thewave
variable index
//---------loop-----------------
for(index=1; index<6;index+=1)
thewave="c"+num2str(index)
duplicate $thewave, w          //error: expected wave name
chi_all[index-1]=RBS_Chi_Cal(r1,w,670, 720)//call "RBS_Chi_Cal" function
//---------loop------------------
edit chi_all
procedure.ipf (3.6 KB)
make /O/N=5 chi_all
string thewave
variable index
WAVE wr=$thewave
duplicate/O wr, w
edit chi_all
Hi Jim,
Thanks for promote reply. I tried again. There's still something not right.
Error message shows:"while executing duplicate, the following error occurred: expected wave name."
make /O/N=5 chi_all
string thewave
variable index
WAVE wr=$thewave
duplicate/O wr, w
edit chi_all
Ah, I see: you're passiing wave parameters using local names c1 through c5 and trying to use $str to refer to them.
That's not really something that WAVE w=$str is designed to do.
You can assign WAVE references, though, so something like:
WAVE cw
switch(index)
case 1:
cw=c1
break
case 2:
cw=c2
break
case 3:
cw=c3
break
case 4:
cw=c4
break
case 5
cw=c5
break
endswitch
//Duplicate/O cw/w why?
chi_all[index-1]= RGS_Chi_Cal(r1,cw,670,720)
may be what you need to do.
How about passing a wave of wave references?
Have a look at the /WAVE options:
DisplayHelpTopic "Wave Reference Waves"
HJ
PS - Bonus: You are "not" limited by the amount of waves to pass.
Thanks. I tried the code below. It does do the magic.
But I am still wondering if there's some way that I don't need to assign the value to "wave reference wave" value one by one.
5 items is fine in this case, but 100 items would kill me.
make /wave/o wr
wr[0]=c1;wr[1]=c2;wr[2]=c3;wr[3]=c4;wr[4]=c5// Is there any alternative way I could not have to  assign the value one by one?
make /O/N=5 chi_all
variable index
//--------loop-----------
for (index=0;index<5;index+=1)
chi_all[index]=RBS_Chi_Cal(r1,wr[index],670, 720)//call "RBS_Chi_Cal" function
print chi_all
HJDrescher wrote: How about passing a wave of wave references?
HJ
The only way I see that this works is when c1 ... cN are waves that are only 1 point long or contain exactly the same value. Otherwise, it is entirely confusing. Please tell us what c1 ... cN really are. Are they waves that have only 1 point in them or waves that have the same value in them?
Also, please tell us what the function RBS_Chi_Calc(...) takes as input. As near as I can tell, it must take a wave and three variables.
The best I can guess is that you probably want something like this ...
Function MyExperimentSetup(nexp)
	variable nexp
	… do what is needed to create r1 and cwave from your data …
	… I am guessing here
	make/N=(nexp) cwave
	… whatever is needed to do this next step is left as an exercise for the reader
	cwave[0] = c0
	cwave[1] = c1
	… do the calculations
	make/O/N=(nexp) chi_all
	chi_all = RBS_Chi_Calc(r1,cwave[p],670,720)
	edit chi_all
The basic idea would be to pass the references as follows
function experiment20151116_RBS_Chi_Cal(r1,c_wave)
wave r1
wave /WAVE c_wave //  <<----------------
for (i=0;i<numpnts(c_wave);i+=1)
WAVE process_c= c_wave[i]  //  <<----------------
HJ
