Curve fitting with functional variables
To give a short example of what I am talking about:
a = (1/b+1/c)^-1
d= (Exp[-w^2 a]
f= Log[sqrt[cosh^2[d]]]
This is anything close to the actual function I am dealing with, but those details are (I believe) unimportant. What is important is a final function ("f") that is dependent on other "functional" variables. How does one deal with them within Igor? What suggestions does the community have for this type of situation? This is fairly straightforward to do in Mathematica, but inconvenient as one has to export the data just right, and set up the directory for Mathematica to import, etc. In addition, graphs are VERY difficult to manipulate in Mathematica, so I'd rather not have to resort to using it if possible. I'm really not sure where to go from here.
You do not say what your independent parameter is. All you give are fitting coefficients. I am going to assume that w in your expression is the independent parameter. Also, why you have a sqrt of a squared value is a mystery to me. I assume this is an illustration and will make it just sqrt of cosh. Finally, the only two coefficients that I see in this are b and c.
Basically, you can define the parameters within your fit function to collapse all complexities in step-by-step fashion, until you are returning from the fit function the value of just one "internal function".
September 2, 2009 at 03:52 pm - Permalink
Don't forget that the square root of a squared real number is always positive. Or, he could've just used
abs()
September 2, 2009 at 10:07 pm - Permalink
Update: Here is the code I am trying to implement:
Basically, R21 is the function that I am trying to fit my data to. tcp is my independent variable. The wave are the fit parameters. The last time I tried this I actually tried typing in the expanded "R21" as a custom fit with no luck. I get the feeling that a lot of the concepts here are pretty basic for Igor, but I have just had no reason to deal with such a complicated function in Igor before, hence my ignorance. I guess i am kind of stuck of where to go from here though as far as using Igor's curve fitting functionality.
September 3, 2009 at 09:26 am - Permalink
-Mike
September 3, 2009 at 11:10 am - Permalink
September 14, 2009 at 03:02 pm - Permalink
Well, cosh(x) and sinh(x) both become very large at rather modest values of x. Is that perhaps part of the problem?
September 15, 2009 at 03:58 pm - Permalink
September 16, 2009 at 11:09 am - Permalink
At some point you simply have to accept the limitations of floating-point arithmetic. Even though floating-point numbers often give the impression of being continuous, they actually have finite resolution.
Having said that, there are sometiimes ways to get around such problems by careful ordering of operations (like do divisions before mutliplications if that will tend to keep the results nearer to 1). You may be able to scale the problem to keep the magnitudes nearer to 1d.
September 17, 2009 at 03:21 pm - Permalink
