WAVE for a 2D wave?
I need to access a 2D wave in a function:
Function (wave2D)
WAVE wave2D
....etc.
But this does not allow me to use two dimension parameters wave2D[i,j] when I try to write some "for" and "if" language in my Function. It allows only one dimension parameter. If WAVE is a wrong definition for my wave2D, what is the correct one?
Thank you,
jjweimer
isend wrote: ... But this does not allow me to use two dimension parameters wave2D[i,j] ... what is the correct one?
The correct notation for a 2D wave is illustrated below.
Function MyCalculation(ww)
    wave ww
    variable a, b, c
    // get the 0,4 value
    a = ww[0][4]
   // transfer ten row values at column index 3 to a different wave
   make/O/N=10 yy
   yy = ww[p][3]
johnweeks
And, of course, you may wish to check out the documentation by executing the following commands on Igor's command line:
DisplayHelpTopic "Multidimensional Waves"
DisplayHelpTopic "Multidimensional Wave Indexing"
