Simple String Input for Panel
I've copied some code from this thread:
http://www.igorexchange.com/node/5588
and modified it a little, to have the below. It makes a simple panel with functional button and non-functional string input.
I'm not familiar with panel coding, and am not sure why the string gets erased after I type in the sample entry.
Menu "Analysis"
	"Open Calculate Panel",/Q, OpenCalculatePanel()
Function OpenCalculatePanel()
	DoWindow/K CalculatePanel
	Newpanel /W=(248,115,730,626)/N=CalculatePanel // apear the panel
	modifypanel cbRGB=(0,39168,39168),fixedsize=1 //color of panel
	showtools /A
	setdrawlayer/K userback
	Setdrawenv fsize=20,fstyle=1,textrgb=(65535,65535,65535)
	drawtext 115,32,"Load Files and Parameters"
	//drawpict 2,2,2,1,1	//no: 4 numbers and a picture name are needed here
	Button button1,pos={160,165},size={161,35},proc=buttonproc,title="Load Waves"
	SetVariable sample_name title="sample ",size={200,136},pos={136,100},proc=setvariableproc
Endmacro
Function ButtonProc(ctrlname) : ButtonControl
	string ctrlname
	Print "Button pressed"
	// Call your calculate routine here
Function setvariableproc(ctrlName) : setvariablecontrol
	String ctrlName
geologic
I've modified the setvariableproc function to give this:
Menu "Analysis"
	showtools /A
Endmacro
	string ctrlname
	String ctrlName
	controlinfo setvariableproc
	print s_value
The error is "expected right parenthesis." I can't find a left parenthesis that is unaccounted for...
jjweimer
Start with this instead ...
Menu "Analysis"
	Button button1,pos={160,165},size={161,35},proc=ButtonProc,title="Load Waves"
	SetVariable sample_name title="sample ",size={200,136},pos={136,100},proc=SetVarProc, value=_STR:"Hello World!"
Function SetVarProc(sva) : SetVariableControl
        STRUCT WMSetVariableAction &sva
        switch(sva.eventCode)
               case 1:
               case 2:
               case 3:
                     print sva.sval
                     break
        endswitch
Function ButtonProc(ba) : ButtonControl
        STRUCT WMButtonAction &ba
        switch(ba.eventCode)
               case 2:
                     print "Button Pressed"
                     break
        endswitch
Learn to use the new structure forms of the controller functions. They are generated automatically when you press the New button on the edit dialog box for the control itself.
Your code was missing an assignment for the value for the setvariable.
Edit: Fixed to show string variable not number value
geologic
This is great.
I've documented my understanding of some of the code. I've also simplified to get at what I would like my button to do: make a string in root and call another function. It works!
// creates selection in analysis pull down menu
Menu "Analysis"
// creates panel, defines operations
// make space for the pane to live, name it
// create a button, with title "Load Waves" that execeutes the procedure ButtonProc when pressed
	Button button1,pos={160,165},size={161,35},proc=ButtonProc,title="String Maker"
// ButtonProc runs when the button is pressed.
// The action procedure, which may be a function or a macro, has the format:
//Function procName (ctrlName) : ButtonControl
//	String ctrlName
//End
// The ": ButtonControl" designation tells Igor to include this procedure in the Procedure pop-up menu in the Button Control dialog.
//A Button action procedure using a structure has the format:
//Function newActionProcName(B_Struct) : ButtonControl
//	STRUCT WMButtonAction &B_Struct
//End
// i suppose ba stands for "button action" and is the manner in which
// button is used
// why is WMButtonAction important? It isn't used elsewhere in the code
 // case 2 tells you that the mouse click has been released (click, then let go)
               case 2:
                     setdatafolder root:
                     string/g string1 = "string created"
                     youdiditalert()
// break is not strictly necessary but recommended and usually necessary
                     break
        endswitch
function youdiditalert()
doalert 0, "you did it!"
return -1
geologic
Ok, I think I've gotten the variability I would like now to build a more complex panel.
Thanks a lot for the starter code and for pushing me to use STRUCT framework. The ability to pull values from the input is convenient!
Menu "Analysis"
	SetVariable sample_name title="sample ",size={200,136},pos={136,100},proc=SetVarProc, value=_STR:"sample name"
	SetVariable ref_name title="reference ",size={200,136},pos={136,200},proc=SetVarProc, value=_STR:"reference name"
	SetVariable temp_list title="temperature list ",size={400,136},pos={40,300},proc=SetVarProc, value=_STR:"temperature list;separated by ; ex. 10;20 "
               case 1:
               case 2:
               case 3:
                     string/g sam = sva.sval
                  if(cmpstr(sva.ctrlname,"temp_list")==0)
                     print sva.ctrlname
                     break
        endswitch
jjweimer
Consider this instead ...
	switch( sva.eventCode )
		case 1: // mouse up
		case 2: // Enter key
		case 3: // Live update
			print "you have changed ", sva.ctrlname
			strswitch(sva.ctrlname)
				case "temp_list":
					// do stuff here
					break
				case "...":
					// do stuff here
					break
			endswitch
			break
			break
	endswitch
I recommend not to store switch values in globals when you can instead get their values as needed with ControlInfo.
jjweimer
This is the WaveMetrics internal structure for button actions. Its storage location is "pointed to" by the reference &ba.
A pointer &ba is an address to the location of the WMButtonAction structure. The structure has all the values (strings, numbers, titles, mouse states ...) in it. The function call looks up the address &ba, goes to it, and reads the values in the (well-defined) WMButtonAction structure.
geologic
jjweimer wrote: > // why is WMButtonAction important? It isn't used elsewhere in the code
Yeah, I've been learning about this today. I like this feature! I don't exactly understand the syntax, with the ampersand and stuff...but if I take it as a given, everything is going smoothly. And I've been able to extract other values as well.
geologic
jjweimer wrote: Consider this instead ...
		case 1: // mouse up
				case "temp_list":
					// do stuff here
					break
				case "...":
					// do stuff here
					break
			endswitch
			break
			break
	endswitch
I responded to this in a separate thread, because I think it's a separate topic: http://www.igorexchange.com/node/7118
Thanks for the advice...see what I did there and let me know if I'm headed towards a dead end with the way I use global strings and variables. I *think* I'm safe, but I'd like to hear what you guys think.
