Read the number of frames in TIFF stack without loading?
I need to record the number of frames in each TIFF stack from a few hundred TIFFs in various locations over a network connection. My code loads each TIFF, records the
dimsize into a numeric wave, filename into a textwave, killing each image before loading the next TIFF. It runs quite slowly and I'm wondering if there's a way to get the TIFF dimensions without actually loading, which would speed things up a lot.Something like
XLLoadWave/J=1 but for images?
Try using the command with the /RTIO tag to read tags only. Try this initially with a few images to see if you can determine if there is a tag with the number of frames in the stack. Also this command creates a variable called that may be what you need.
It's been quite a while since I've worked with tiff stacks, but there may not be a standard implementation for stacks; it may vary with the software creating the files. (A quick look at Adobe's spec for TIFFs seems to bear this out, but I'm sure someone will correct me if I mistype here.) If so, you will need to look to the software for specific details. However, with the /RTIO tag and files with a known format, you should be able to find and answer to your question.
Hope this helps.
Post an example file (as small a file as possible) if you need more assistance.
September 12, 2016 at 07:19 am - Permalink
In some special cases, when all the images are saved with the same size (no compression), you can estimate the number of frames from the size of the file and the size of an image and IFD.
September 12, 2016 at 10:46 am - Permalink
Just one observation in case it is helpful for anybody. Once loaded, the string variable is populated with a separated list of values. This contains number of frames. Parsing that string is a possibility, but using is easier. This still requires loading the files.
Example of
September 13, 2016 at 05:54 am - Permalink
What operation or function are you using to load the TIFFs?
September 13, 2016 at 05:05 am - Permalink
September 13, 2016 at 05:55 am - Permalink
Yes -- odd.
I looked through several image loaders and didn't see one that created s_info. I also tried drag/drop onto IP6 & IP7, while this loaded my test image, s_info was not created. Maybe you initially used a package or example experiment?
September 13, 2016 at 06:41 am - Permalink
TIFFReadDirectory: Unknown field with tag 50838 (0xc696) encountered
TIFFReadDirectory: Unknown field with tag 50839 (0xc697) encountered
twice for each file. I'm guessing this is the information stored in S_info, but it's a mystery why it loads OK by drag and drop.
September 13, 2016 at 08:02 am - Permalink
September 13, 2016 at 10:40 am - Permalink
When you use ImageLoad to read a TIFF image that contains Tag 270 (IMAGEDESCRIPTION), the contents of the Tag data are written to S_info. If you are reading multiple TIFF images from a stack then the contents of the very last Tag 270 will be in S_info. Using this to deduce the number of images assumes that the contents of the tag would (a) exist and (b) be accurate.
Using /RAT is a more reliable approach.
September 13, 2016 at 11:01 am - Permalink
September 13, 2016 at 11:32 am - Permalink
Hope this helps.
Kurt
September 13, 2016 at 11:11 pm - Permalink
September 14, 2016 at 11:04 pm - Permalink
FWIW, the RAT tag in Igor Pro now does the equivalent to the TIFFTagReader code.
I believe that the TIFFTagReader code does not work properly for multi-page files. The issue seems to be with how the reader resets the file position to move to the next IDF position. I think instead of setting the next read position as the vdata value, the file position has to be moved by vdata times the byte count *from* the current position.
Anyway ... if you are still around, thank you Kurt. The reader helped me systematically deconstruct how a TIFF file is stored first hand beyond just reading a scattering of Webpages about the format itself.
June 13, 2019 at 04:52 pm - Permalink
In reply to FWIW, the RAT tag in Igor… by jjweimer
KurtBHi Jeff,
I am still here, and you are very welcome.
I spent a great deal of time during my PhD days (early/mid 90's) writing code to read and extract data from many propriety and often opaque instrument specific file formats so that I could do my analysis etc in Igor. I wrote TIFF read/write code to use and store instrument specific configuration data in the private tags, but still have the main data in a standard, universal file format. The code I posted some years ago was adapted from that behemoth. That arm of the business was sold on many years ago now and sadly I have not touched this sort of thing since.
Cheers,
Kurt
June 13, 2019 at 11:43 pm - Permalink
