Need program used for peak deconvolution
The detail problem is that I want to deconvolute the fluorescence decay profiles, which consists the instrument response function and the fluorescence intensity from the sample. Do anyone have experiences on this stuff? Thanks!
http://www.igorexchange.com/node/1371
Other than this, I am unaware of any other deconvolution packages for Igor Pro.
October 3, 2016 at 09:41 am - Permalink
Ah- you are talking about a single peak? No doubt it is a convolution of some sort of impulse-like shape with an exponential decay. It's possible that Multipeak Fit 2 can still help you, even though it's only a single peak. I would look at the ExpModGauss and the ExpConvExp peak shapes.
October 3, 2016 at 09:43 am - Permalink
Thanks for the information, but I didn't find where to download the procedure in your link, can you send me the download link?
October 5, 2016 at 11:46 am - Permalink
Thanks very much, I will try this soon!
October 5, 2016 at 11:47 am - Permalink
The method that @johnweeks mentions should do better than what I have. AFAIR, I never did generate a revised version of the deconvolution routine, and it is better suited to deconvolve a transmission function from a peak in spectroscopy than an exponential decay curve.
October 5, 2016 at 05:18 pm - Permalink
October 11, 2016 at 03:08 pm - Permalink
