string as a wave reference...
I'm sure this has been posted before but I can't seem to find the answer via search...
I have 2 waves loaded from a csv data file. 1 wave, strwv, contains a list of strings that repeat but are not in any particular order, e.g.
yes,no,hi,bye,no,yes
and the second wave, varwv, contains values that go along with those strings. (arbitrary e.g. 1,2,4,8,199,0.2)
I would like to make a new set of waves that are named based on the points in strwv and filled with the corresponding points in varwv. So the wave "yes" from the arbitrary example above would contain 2 points: 1 and 0.2.
This what I have so far with minor exception catching:
Function ParseLoadedData()
	string wvlist = WaveList("*",";","")
	if (strsearch(wvlist,"variable",0)>0)		// make sure variable wave loaded
		wave/T variableW
		wave value
		variable totalpnts= numpnts(variableW), i, tempnum
		string tempstr
		for(i=0; i<totalpnts; i+=1)
			tempstr = variableW[i]
			if(waveexists($tempstr)==0)	//check to see if the variable has a wave made already, if not then make it
				Make/D/N=1 $tempstr
				$tempstr[0] = value[i]		//and assign that value to position 0
			if(waveexists($tempstr)==0)	//if variable is already a wave...
				tempnum = numpnts($tempstr)
				insertpoints tempnum,1,$tempstr  //want to insert new points at the end not beginning
				$tempstr[tempnum+1] = value[i]
The problem here is that $tempstr[i] throws a "can not use $ in this way" error. Do I need to use the
/wave
flag on the Make statement? If so, how do I keep track of that between the 2 if statements?
Thanks for any help.
johnweeks
Here is how I would do it:
		wave/T variableW
		wave value
		string tempstr
			WAVE/Z tempwave = $tempstr
			if(!waveexists(tempwave))	//check to see if the variable has a wave made already, if not then make it
				Make/D/N=1 $tempstr
				WAVE tempwave=$tempstr
				tempwave = value[i]		//and assign that value to position 0
			if(waveexists(tempwave))	//if variable is already a wave...
				tempwave[tempnum+1] = value[i]
I have compiled it, but I haven't tried to run it...
If your waves are long, you may have troubles with performance. Both constantly looking up the waves using WAVE statements, and constantly adding one point are costly ways to do this. In a case like this, if performance is a problem, I would probably reduce the need for InsertPoints by make waves with lots of points to start with, and then reduce their length when it's finished. You might also be able to keep store a wave reference for each wave, allowing you to avoid the wave look-up. But that is complex and would only be potentially important with many, many waves.
jjweimer
Why not use the two waves this way ...
* convert text wave to a variable mask wave for each text value
* use the mask to sort and remove unmatched items
* create the new wave for the given string
I think of some thing like this (fix the syntax though because this is off the top of my head) ..
... loop here ...
string mstr = "yes" // then "no" then "hi" then ...
string nvwave = mstr + "_values"
duplicate/FREE variableW variableWtmp
duplicate/O variableValues $nvwave
wwmask = cmpstr(variableWtmp,mstr) ? NaN : 1
sort ... // sort variableWtmp and $nvwave based on wwmask
cut ... // cut all values in $nvwave on values that are NaN in wwmask
Voila ... you have your new wave with the data points.
igorisfun
John, thanks for the quick fix, I knew there was something simple I was missing.
jjweimer: that's definitely a more elegant solution than mine! That's actually exactly how I checked my solution in excel (filter->sort)...I will have to play around with it!
