VAMAS file format
Does anyone know about "VAMAS Surface Chemical Analysis Standard Data Transfer Format"? It appears to be identified by the .vms extension. Is it a common format? Has anyone written an Igor loader for it?
chozo
I don't think it is a too common format (documentation etc. is rather sparse), but I encountered it when working with a commercial XPS apparatus (JEOL Ltd.). I guess it is mostly found with commercial analytical apparatuses.
Anyway, I wrote a parser which goes through all relevant lines of a file using FReadLine (but in the end only extracts the information I was interested in at that time). I cannot claim that it will work for everything, but maybe this can serve as a starting point. I also attach four generic example files I found somewhere. Hope that helps.
VAMAS parser.ipf (8.92 KB) VAMAS files.zip (8.25 KB)
thomas_braun
VAMAS is common as an exchange format defined for surface science data, mostly XPS. It's defined in a publication [1] and a slightly modified ISO standard [2]. See also [3].
Many commercial XPS fit programs like CasaXPS [4] or UniFit[5] can read it.
I've written a VAMAS writer in C++ (which I'm afraid I can not share) but no VAMAS reader. The VAMAS format itself has the notion of blocks, so you could use a
LoadWave
command from time to time to avoid the slow
FReadLine
for data itself.
The format itself is quite vast looking at the spec but it's mostly used for 1D data with one or two experiment variables.
[1]: http://onlinelibrary.wiley.com/doi/10.1002/sia.740130202/full
[2]: http://www.iso.org/iso/catalogue_detail.htm?csnumber=24269
[3]: http://www.npl.co.uk/science-technology/surface-and-nanoanalysis/servic…
[4]: http://www.casaxps.com/
[5]: http://www.uni-leipzig.de/~unifit/
johnweeks
Thanks, guys!
I ran across VAMAS format while looking for data to use in testing a built-in Voigt fit function. The data was from CasaXPS. For myself the need is very low priority, but having run across the format I thought I'd see what it was all about.
jjweimer
Wow! There are a lot of other useful file loaders there too one level up.
Thanks.
