Multivariate Derivative
I have the exponential rise and decay function
f(t) = Amplitude*(1 - exp(-t/Rise))*exp(-t/Fall) + Offset
with Rise and Fall time constants.
I need to find the numerical derivative of this function with respect to the following parameters
1) Rise
2) Fall
3) Offset
4) Amplitude
Is there a way Igor can do this?
If I understand, you want to do partial derivatives numerically? I cannot address this. I can however offer a different idea.
The partial derivatives exist analytically. By example: (df/dR) = -A*t*exp(-t/R)*exp(-t/F)/R^2. Fit your measured data to the equation and obtain A, R, F, and O. Generate a wave to show the derivative equation using the fit coefficients.
make/N=101 dfdR
dfdR =  -A*x*exp(-x/R)*exp(-x/F)/R^2
display dfdR
BTW, (df/dO) = 1 and (df/dA) = 1. Why would you want these?
Yes numerical partial derivatives is the goal. I plan to use them all to weight a fitting function. Since MATLAB has a way to do this, I wonder if Igor does.
It's called Differentiate. To do the partials you want, you would need a wave full of values of f(t), and a wave full of values of each of the independent variables. Then use Differentiate with your f(t) wave as the Y wave and one of your independent variable waves as the X wave.
To follow on John Week's comment, you will have to
* fit your data to the model
* extract the fit parameters
* create a new wave called the "x-wave", one for each parameter
* numerically differentiate the y-data with respect to each x-wave
So, let's suppose that you have fit the data to your equation and have determined A, R, F, and O. You have stored the values in variables vA, vR, vF, and vO. You have your data in a wave called fwave. Here's how to get dfdA numerically.
duplicate/O fwave, xAwave, dfdA
xAwave = vA
differentiate fwave /X=xAwave /D=dfdA
John please correct me if I am wrong in any of this.
