Duplicating a wave, same name, different folder
SetDataFolder $DataFolderName
Duplicate root:wave0, wave0
is what I think should work, but I get an error about trying to duplicate into the same wave, even though my intent is to duplicate root:wave0 to root:DataFolderName:wave0. DataFolderName is distinct from root.
November 2, 2016 at 10:19 am - Permalink
Your reminder to use was very helpful. Inevitably, I will forget to actually load the data. I should also mention that since the procedure is in active transition, I intend to label the subfolder "wave0" with something more sensible, like "RawData". And all of this is in a subfolder that contains date and file index (from that particular day, e.g., 20161102_04).
November 2, 2016 at 12:09 pm - Permalink
Yes, you didn't post your complete function, but if it was like this:
then, yes, it is the WAVE statement that was responsible.
WAVE statements do two different things, one at compile time and one at run time. At compile time, it establishes a name as an alias for a wave that doesn't necessarily exist at the time. The WAVE statement allows Igor to compile wave handling code when it sees that name later in the code.
At run time, when the WAVE statement is encountered, it causes Igor to look up a wave with the specified name and causes that name to be associated with a real wave. In this case, the real wave is the one in the root folder, so the Duplicate command is asked to duplicate root:junk onto the wave previously looked up, which is root:junk. The wave reference doesn't stop pointing to the original wave just because you changed the data folder.
In addition to my explanation above, there are some convenience behaviors that can be confusing.
The basic WAVE statement works like . That establishes "localname" as an alias at run time for "globalname" in a data folder that isn't necessarily the current data folder. But Igor also allows a shortcut: . That makes a local alias "globalname" for a wave called "globalname" in the current data folder. The confusing part is that the localname is the same as the real globalname, but in fact, in the function "globalname" is a local alias that happens to have the same name as the actual wave.
Another source of confusion is that some commands that create waves can sometimes make a wave reference. In particular, Make and Duplicate (and some others) if you give it a literal name will make a wave reference for you without requiring a WAVE statement. So will make a wave in the current data folder called "myWave" and it also creates a wave reference with the local alias name "myWave", just as if you had used the shortcut .
Completely clear now, right? :)
November 3, 2016 at 11:56 am - Permalink
The rules are somewhat complex and depend on the rtGlobals statement in your procedure file.
For the complete story, execute this:
For simplicity, I recommend you follow this rule:
"Simple name" means just a standard (not liberal) wave name (e.g., wave0) with no path (root:wave0 is not a simple name) and with no use of strings or $.
Examples:
November 3, 2016 at 03:04 pm - Permalink
