Fit curve with convolution of two functions
I am trying to fit a part of a curve defined by cursors with a convolution of a function ( a+b*x^n) with another shape 'beamg'
Function sbeam(pw,yw,xw) :FitFunc
Wave pw,yw,xw
Variable dT = deltax(xw)
make/D/O/n=401 beamg
setscale/I x, xw[0],xw[400], beamg
if (.000149 beamg = -0.9649+ 2.0288*exp(-221.69*xw)
elseif ( .00283 beamg = -.00898 +.028645*exp(-60.94*xw)+4.0557*exp(-1300.5*xw)
beamg=0
if (beamg>1)
beamg=1
yw=pw[1]+pw[2]*xw^pw[3]
Convolve/A beamg,yw
This doesnt seem to work at all ... it just outputs 0 . Any idea what is going wrong?
Thanks v much
This doesnt seem to work at all ... it just outputs 0 . Any idea what is going wrong?[/quote]
Well, your Function has the wrong format as a start. Also, you are making a new wave within the function, when perhaps you should have that wave already pre-made prior to the fit function. Finally, what the test "if (.0001491) ..." is supposed to do is unclear (it will always fail).
Perhaps you might start by doing a search on FuncFit with the Igor Help Browser to learn about the Format of a Basic Fitting Function. Also, you might set up all your waves prior to executing this function. This might lead to something on the order of ...
I have to admit being a bit fuzzy on how to handle the convolution inside the FuncFit expression and will defer to someone else for this part of your problem.
November 20, 2009 at 02:17 pm - Permalink
Also, this line:
seems unlikely to be what you intended. more likely
or something similar.
November 20, 2009 at 02:58 pm - Permalink
[/quote]
The format is OK- it's an all-at-once fitting function.
November 20, 2009 at 03:00 pm - Permalink
[/quote]The format is OK- it's an all-at-once fitting function.[/quote]
My apologies. I had never used such a function before.
November 20, 2009 at 06:26 pm - Permalink
I am sorry there was an error in copying the previous piece of code. I have been working more with it, and have got the convolution to work , however it shows the convolution to be shifted in x space. I have attached an image showing the original data, yw , beamg and the 'fit'.
this is the code I am using:
Wave pw,yw,xw
setscale/P x, -200*dT,dT, beamg
beamg = (abs(xw/dT) > 0.000149 && abs(xw/dT) < 0.00283)*(-0.9649+ 2.0288*exp(-221.69*abs(xw/dT)) + (abs(xw/dT) > 0.00283 && abs(xw/dT) < 0.3)*(-.00898 +.028645*exp(-60.94*abs(xw/dT))+4.0557*exp(-1300.5*abs(xw/dT))))
if (beamg>1)
beamg=1
yw=.5*exp(- ((xw/dT)/pw[1])^2) // + pw[4]*(abs((xw-pw[5])/dT)^pw[6]) )
Convolve beamg,yw
Convolve/A and /C do not seem to help either. My original curve is centered about zero , how should I shift the convolution to do the same?
Thanks very much
November 21, 2009 at 03:43 pm - Permalink
Wave pw,yw,xw
if (beamg>1)
beamg=1
Convolve beamg,yw
Thanks very much[/quote]
I think your code makes an assumption in this line:
If you use the Autodestination feature (/D flag, or choose Auto in the Output Options tab of the Curve Fit dialog) your fit function will be called with yw and xw having 200 points. You need to account for the possibility of getting different numbers of points in yw and xw. Or you might use /D=- that way your function will be called only with yw and xw having the same number of points as your data.
If you haven't already done so, be sure to read the section of the description of all-at-once fit functions that describes the "more complicated" example. That example handles a number of shortcomings of the easier, less complicated first example.
November 30, 2009 at 11:08 am - Permalink
