tag lines and tag boxes ordering
The following code
Function CreateData()
	Make/O AD0 = 1/20*p
	Make/O AD1 = 1/20*p
Window MyGraph_1() : Graph
	Display /W=(191.25,511.25,786.75,801.5)/L=row0_col0_1 AD0
	AppendToGraph/L=row0_col0_2 AD1
	ModifyGraph margin(bottom)=85
	ModifyGraph rgb(AD0)=(7967,7710,7710),rgb(AD1)=(60395,52685,15934)
	ModifyGraph nticks(bottom)=8
	ModifyGraph lblMargin(bottom)=48
	ModifyGraph standoff(row0_col0_1)=0,standoff(row0_col0_2)=0
	ModifyGraph lblPosMode=1
	ModifyGraph lblLatPos(bottom)=-34
	ModifyGraph tickUnit(row0_col0_1)=1,tickUnit(row0_col0_2)=1
	ModifyGraph freePos(row0_col0_1)=0
	ModifyGraph freePos(row0_col0_2)=0
	ModifyGraph axisEnab(row0_col0_1)={0.515,1}
	ModifyGraph axisEnab(row0_col0_2)={0,0.485}
	Label row0_col0_1 "AD0\r(pA)"
	Label row0_col0_2 "AD1\r(pA)"
	Tag/C/N=text_1/X=0.00/Y=-24.81 AD0, 60, "my label"
	Tag/C/N=text0/F=0/X=61.46/Y=-0.78 AD0, 0, ""
EndMacro
Gives the attached graph. Is there a way I can move the tag line behind the textbox?
Thomas
What happens when you make the background on the tag solid? Does that fill in to hide the tag line in the way you need?
Reverse the order of the Tag commands:
@jjweimer: It is already solid.
@JimProuty: Thanks that worked. So there is no interactive method?
