Extrapolate using curvefit without plotting
Using curvefit, I am able to extrapolate by first plotting then using the Curvefit/X=1 flag to indicate to do the fit over the entire x-range.
I am doing a lot of fitting in a loop, and don't need to actually plot the data.
As I would like to keep this fast, is there a way to have the output fit wave extend over a certain range without first plotting?
I know I could simply use the fit coefficients, but I am also extrapolating the prediction bands for which there are no coefficients generated.
Is there a method for extrapolating prediction bands using curvefit without plotting first?
Also, as I am doing a polynomial fit, I am aware that this is only an approximation. I am not extrapolating far, so this is a risk I am willing to take.
Thanks.
HJDrescher
The
/W=2
flag should do the job, if I understand your question correctly. However, this should be the default option when
curvefit
is called from a procedure (since I see the words 'loop' and 'fast' -- see the IP7 help file -- looking at my IP6 code I'm not 100% sure if this is also true for the IP6 help file; Just test it).
Anyway, existing plots *might* get updated (
doupdate
somewhere in the code) causing additional computation time. Minimize or kill/recreate the window in these cases.
HJ
BMangum
Thanks for the input, the /W=2 helps a bit (and might be good enough), but I have no need to even plot the data in the first place.
I am calling
curvefit
from a procedure and just want to extend the fit over a range that I can specify rather than plot the wave first.
hrodstein
I am calling
curvefit
For an example of extrapolating a fit result, execute:
DisplayHelpTopic "Extrapolating a Fit After the Fit is Done"
If that is not clear, go back to "Guided Tour 2 - Data Analysis" and do the tour through "Extrapolating a Fit After the Fit is Done".
Although this example involves plotting, the extrapolation part does not require it.
BMangum
Thanks hrodstein, let me clarify a little:
Extrapolating the fit itself is not an issue as the equation for the curve and the coefficients are reported out.
The problem I am having is extrapolation of prediction bands and confidence bands without first having to plot the data.
johnweeks
I was looking into how to compute those curves when I got sidetracked onto creating a NIDAQ Tools MX installer that will work with Igor 7...
The solution involves the covariance matrix and chi-square...
hegedus
I would like to revisit this request.
I am in similar need.  I would like to do a curvefit of permutations of the data and then extrapolate from those fits to a new condition.  Additionally I would like to include the prediction interval of each fit at the extrapolate point.  I can sort of do this using similar approaches with a graphed data set using the above mentioned flag.
Is there a more direct method available in IP8 or 9 to allow me to fully script this?
