Multithread ImageLoad and ImageRegistration
As expected, this process takes several hours due to slow
ImageLoad (that needs hard disk access) and ImageRegistration (that has heavy computation) operations. I have thought about using several threads to speed up the operation, but it seems that neither ImageLoad nor ImageRegistration supports ThreadSafe functions.Any suggestions on how to speed up this task?
I cannot comment on being slow.
best,
_sk
May 4, 2017 at 04:15 am - Permalink
Thanks for the suggestion. Unfortunately the feature in the image is quite small (I'm aligning some discrete set of points) so the coarsest flag I could use is . I guess I may try rescaling the image before calling and see whether rescaling is an expensive operation or not.
Regarding memory usage, I have to load and kill one image at a time. Maybe that's the speed bottleneck?
May 4, 2017 at 07:55 am - Permalink
An SSD might give some speed increase in loading.
May 4, 2017 at 08:44 am - Permalink
FWIW, ImageRegistration is threadSafe in IP7, but that is unlikely to help you because the most probable bottleneck is ImageLoad.
As most of the work here is single threaded you could split your image collection into multiple disk folders and then run multiple instances of Igor to process the data.
May 4, 2017 at 09:45 am - Permalink
It is not clear if these are in separate files or one file.
ImageLoad is not thread-safe. You can run multiple instances of Igor and have each instance work on a different set of files. Or, if they are in one file, use the ImageLoad /S and /C flags to control which images are loaded by which instance of Igor.
According the the help browser, ImageRegistration is not thread-safe in Igor6 but it is thread-safe in Igor7, so you could write a multi-threaded Igor procedure to do the registration. However, if you are going to use multiple instances for ImageLoad, you may as well do it for ImageRegistration also, and then merge the results at the end.
I agree that an SSD drive may help, but with ImageLoad only.
It seems that the best solution is to run multiple Igor instances.
May 4, 2017 at 07:19 pm - Permalink
Maybe or something like this.
Also worth pointing out are and . Maybe you can go around any of the overhead incurred by .
Can you post a representative image?
best,
_sk
May 5, 2017 at 12:42 am - Permalink
When considering "overhead" neither GBLoadWave nor FBinRead are free of "overhead". It is possible that ImageLoad may be relatively slower because of multiple instances of a disk seek/read; something that can be replaced with a single read into a wave followed by multiple wave access to extract the relevant data (this might work if the images are not compressed).
Except for the case of stacked TIFF images, where LibTIFF code is amazingly bad, I would not expect any improvement in trying to roll your own image reading routines. Also, FWIW, the latest IP7 should not be affected by LibTIFF stack performance limitations.
May 5, 2017 at 11:52 am - Permalink
I've found a tiff file here, http://www.fileformat.info/format/tiff/sample/, and then I load that on my machine
this takes between 40 and 70ms. What do you get?
It is loaded from a SSD. Are your TIFF files compressed?
May 6, 2017 at 02:28 am - Permalink
