Why are there THREE layers when I load ONE bmp file ?
Jinhyung Kim
Wed, 06/14/2017 - 09:05 am
I have a simple question.
It may not related to the Igor Pro.
When I load a single bmp file (ex. SEM image or CCD image), there are 3 layers in one bmp wave.
I used the command •ImageLoad/T=bmp (actually 'Load Image...' used from Data tab)
To preview the image in 2D in data browser, I change the number of layers 3 to 0.
I wonder if it is normal or not.
Thanks in advance.
To convert to a single layer grayscale use imagetransform.
imagetransform /O RGB2gray imagename // note this overwrites the image with the grayscale (single layer) image. If you don't want to do that omit the /O flag.
June 14, 2017 at 09:30 am - Permalink
June 19, 2017 at 06:20 am - Permalink
