How to connect from IGOR PRO 7 on MacBook Pro (USB-C) to Mettler-Toledo balance (RS232)
bfrick
Wed, 08/23/2017 - 08:47 am
We try to connect a balance from Mettler-Toledo to the MacBook under Sierra.
connection USB-C tp USB2 to RS232 on balance.
Parameters on balance and IGOR VDT2 XOP set equivalent.
I can see only the following ports:
>print S_VDT
lpss-serial1;lpss-serial2;Bluetooth-Incoming-Port;
Under 'System Report' one can recognise the adapters but not the balance.
Maybe a hint could be that the balance allows only for characters ANSI/WIN or IBM/DOS and nothing like that can be set in the VDT2 settings.
Did you install the drivers for the USB to RS232 connector?
August 23, 2017 at 08:57 am - Permalink
This forum is for discussing the IgorExchange site itself.
The general forum is for discussing how to use Igor.
August 23, 2017 at 09:59 am - Permalink
