Iteration loops (do-while, for) in Igor programs (user functions) seem to execute very slowly on Igor compared to other compiled programming languages. I typically need to modify individual elements of waves, which seems to dramatically slow down execution. Aside from multithreading, are there any recommended methods to make iteration loops run faster on Igor?
I am using Igor Version 7.0.5.2 on Windows 7 Professional.
Please enclose the code in <igor> and </igor> tags so that it gets properly syntax-colored:
October 1, 2017 at 05:09 pm - Permalink
If you are looking for speed use commands such as , and wave indexing (p, q, r), see . But depending on what you are doing that might not always be possible.
October 2, 2017 at 03:34 am - Permalink
I did tests and the results show that Igor programs run faster than Python,Matlab and Origin, greatly faster!
Your case may not be due to Igor. To find the reason it would help if you can show your code.
By the way, do-while loops run quite slowly in proc and macro. for loops can not be used under proc and macro. Please check whether you are using do-while loops in proc or macro!
October 3, 2017 at 05:09 am - Permalink
Can you share the code for the tests?
October 3, 2017 at 10:40 am - Permalink
The test is to calculate fibonacci sequence using recursive algorithm.
1 In Igor:
result is about 2.4 seconds
2 Program an XOP to calculate fibonacci sequence by C and call it from Igor:
XOP C Code:
Igor code:
result is amazing, about 0.1 seconds, even faster than that in C++ (Visual Studio 2015)
3 In VS 2015, C++
result is about 0.5 seconds
4 In Matlab:
function y=fib(x)
if x<2
y=x;
return;
y=fib(x-2)+fib(x-1);
result is about 73 seconds
5 In OriginPro 2016
result is about 138 seconds
BTW, the result depends the performance of the computer. The tests above were done on a notebook PC.
In my new desktop PC with higher performance, time required in Igor Pro 7 is about 1.2 s.
October 3, 2017 at 05:25 pm - Permalink
ffib := proc (x) local y; if x < 2 then y := x else y := ffib(x-2)+ffib(x-1) end if; y end proc:Time was ~12.6 s.
I ran your code in Igor64. Time was 1.2s
MacBook Pro Late 2013 with 16GB RAM.
(I am curious what you get with Matlab and Origin on the higher performance system where the Igor Pro / Igor64 times are comparable to my MBP).
October 3, 2017 at 09:13 pm - Permalink
do you mean the time required in Matlab and Origin is comparable to Igor to your MBP?
October 3, 2017 at 10:37 pm - Permalink
I get 10 ms for the code below
October 4, 2017 at 12:59 am - Permalink
I take this low efficiency algorithm purposely because I want to know the performance of Igor. Recursive algorithm consumes memory and cpu resource greatly, so it is a good choice to test the performance of the Igor's compiler. There are of course better ways to calculate Fibonacci Sequence. The code follows only takes about 4 micro seconds (In my PC, your code takes about 6.6 micro seconds):
October 4, 2017 at 01:45 am - Permalink
No. I am curious what YOU get with these two apps on your faster machine. I have yet to update Matlab on my system.
October 4, 2017 at 06:34 am - Permalink
I did not test that on my fster machine because I did not not install Matlab and Origin on it...
October 5, 2017 at 07:29 pm - Permalink
October 5, 2017 at 06:56 am - Permalink
Igor Version: 7.0.5.1 (Build 29707) 1.84 seconds
PyPy2 V5.9.0-win32 140 ms
JavaScript (Chrome Version 61.0.3163.100 (Official Build) (64-bit)) 107 ms
Julia 0.6.0 53 ms
Assembly - who knows how to write assembly? not me!
October 9, 2017 at 10:34 am - Permalink
October 9, 2017 at 11:41 am - Permalink
Wow. That sounds like a politician, doesn't it?
You can time raw function-call overhead:
On my 5k iMac:
•testCall(1e6)
Function call time: 3.30899e-08
Not too bad!
October 9, 2017 at 03:27 pm - Permalink
Agreed, especially when considering the for loop is inside the timer.
October 9, 2017 at 09:32 pm - Permalink
October 10, 2017 at 09:33 am - Permalink
Sorry I missed that.
- Tim
October 16, 2017 at 10:03 am - Permalink
