Delete all graphs that are NOT part of layouts
Is there a way to Delete all graphs that are NOT part of layouts
Hi Supriya,
One strategy:
Use Winlist to get a master list off all open windows.
Use Winlist to get a list of all Layouts and remove those window names from the master list.
Use Layoutinfo for each layout to get a list of objects used in each layout and remove those windows from the master list.
What is left is a list of windows not included in any open layout which can be killed/closed.
Here is a solution that I have tested only very briefly:
Function IsGraphInLayout(graphName)
    String graphName
    String layoutList = WinList("*", ";", "WIN:4")
    Variable numLayouts = ItemsInList(layoutList)
    Variable layoutIndex
    for(layoutIndex=0; layoutIndex<numLayouts; layoutIndex+=1)
        String layoutName = StringFromList(layoutIndex, layoutList)
        Variable objectIndex = 0
        do
            String objectIndexStr
            sprintf objectIndexStr, "%d", objectIndex
            String info = LayoutInfo(layoutName, objectIndexStr)
            if (strlen(info) == 0)
                break                       // No more objects in this layout
            String typeStr = StringByKey("TYPE", info)
            if (CmpStr(typeStr,"Graph") == 0)
                String nameStr = StringByKey("NAME", info)
                if (CmpStr(nameStr, graphName) == 0)
                    return 1                // The graph is in this layout
            objectIndex += 1
        while(1)
    return 0        // The graph is not in this layout
Function KillGraphsNotInLayout()
    String graphList = WinList("*", ";", "WIN:1")
    Variable numGraphs = ItemsInList(graphList)
    Variable graphIndex
    for(graphIndex=0; graphIndex<numGraphs; graphIndex+=1)
        String graphName = StringFromList(graphIndex, graphList)
        if (IsGraphInLayout(graphName) == 0)
            KillWindow $graphName
            Printf "Killed %s\r", graphName
